New BT-50....rate your genuine accessories!!
Soozooki
Re: New BT-50....rate your genuine accessories!!
Unread post by Soozooki » March 17th, 2016, 8:16 pm
Old thread I know, but I noticed a lot of you guys are having grief with dash squeaks. I had a central/passenger side squeak in cold weather near the windscreen that stopped when you put some pressure on it. I found this solution somewhere online, could have been here, not sure but here goes...
1. Remove the glove box
2. Locate a small bolt inside 5th or 6th demister vent partition from the left under the windscreen (hex/torx, can't remember which one) Undo this almost all the way out.
3. Screwing this out reveals the head of a hex/torx under the dash which attaches the dash to the firewall (it's only blocked from view by the vent bolt). Tighten this firmly.
4. Reverse procedure, tightening the demister bolt and refit your glove box.
I hope this helps some of you out. It stopped mine that's for sure.
