Best Axe/Bock Splitter/Maul for splitting Jarrah Rounds?
Shann Low
Re: Best Axe/Bock Splitter/Maul for splitting Jarrah Rounds?
Unread post by Shann Low » May 13th, 2016, 11:05 pm
Yeah things have slowed a little in the search for the ultimate axe.
The Tuatahi is on order with a 4 month wait.
The chopper 1 resto project is underway with new springs and retainers, pins etc and a new hickory handle on the way from USA.
I am polishing the cast axe head hopefully to a mirror finish on it. Working with various grit flap wheels on the angle grinder to get rid of all the casting pits etc back to bare metal.
I went out today and bought a bench grinder to pull the grinding wheels off and put those sisal and cotton polish/buffing wheels on, and buy some jewelers rouge or whatever its called to buff the axe head up after I get it wire wheeled and sanded down to 1200 grit wet n dry first.
At the same time I am working on making one of these "jigs" for my Makita belt sander to turn it into a linnisher for grinding the edges on the axe heads to 22 degrees.
https://www.youtube.com/watch?v=GvTvEBQ1Lss
I am still after the Grasfors Bruks Splitting maul but that's another $240 plus $30 postage so might have to wait a couple weeks or so, for the bank balance to perk up some first after the hit its taken of late with the Tuatahi purchase.
All up I am approaching $1K so far into this "ultimate" axe hunt!
Probably should take some photos along the way and do some kind of a write up thread I guess.
But the 4 months wait for Tuatahi to arrive will slow things down anyway... likely winter will about all but be over before it gets here.
Not to panic - the eldest lad who these axes/mauls etc are for, is still recuperating from plastic surgery on his arm after his truck roll over accident 3 weeks back, so he won't be swinging axes or wielding the 660 Magnum Stihl anytime soon - which gives me time to potter away at this project (among others) at a leisurely pace, hopefully all coming together when he is ready to get back in the saddle.
At least that's the plan...
Been doing some "interesting" research tho in the meantime on the history of axes in Oz dating back some 40,000 years just out of interest for what its worth.
I've had these couple hand axes and spear heads from the Kimberly's for probably the last 35 years or so - but never knew much about them...
Aboriginal axes would have been either the hand axe type (head held in the hand) or hafted using a fork or bent stick and tied on...
The aboriginals certainly did make and use axes. As I understand it there are two principal types, ground axes and flaked axes.
The axes could be used as a hand axe or hafted to a shaft.
The axes could be used for cutting wood (trees) and butchering animals.
Axes were made from hard rocks which were quarried at specific sites. Many of these sites had specific legends and stories attached to them, which would increase the prestige of obtaining an axe from that site (like Holden vs Ford – you’ve got to have a stone axe from Mount William !).
Quality axes (or axe blanks) were traded over large areas, hundreds of kms and even 1000 km ! This shows trading between tribes was wide spread.
All rocks have a unique chemical composition, so when a stone axe is found, it can be analyzed and its origins determined back to a specific quarry site.
Mount William (Victoria) hosts a large Aboriginal greenstone quarry and axes from this side occure as far away as South Australia’s Flinders ranges.
(Greenstone is geologically related to basalt type materials)
There have been quite a few papers about Mt William, here is a great summary:
Mount William stone axe quarry - Wikipedia, the free encyclopedia
I know some of the NSW contingent have posted grinding groove pictures, it may be interesting to note that quarrying of blanks and polishing often did not happen at the same places.
I was going to point out that stone axes can become chipped, but the edges can be re-worked and the tool can continue to be used, sometimes it is not necessary to remove the axe from the handle to do this.
In the picture it looks like the haft has been achieved by bending a green stick in half, thus forming a “loop” at the top to hold the axe head.
There is probably a strong lashing (perhaps sinew) underneath his hand to hold it tight. The inside of the stick may have been thinned out at the top to help the stick bend without breaking.
It is possible that an adhesive resin, or wax was used too, but I’ve seen examples where none has been used at all and its just the tension from the stick and lashing to hold the head in place.
An adz configuration seems to have been common place too.
The oldest ground-edge axe yet found (in the world) is from 35,000 years ago, found in a rock shelter in Jawoyn country in Arnhem land.
35,000-year-old axe head places Aboriginal ancestors at the cutting edge of technology
Im not sure if older non-ground-edge axes have been found in Australia/Sahul.
Sahul is the name given to the extended Australian/New Guinea/Tas continent etc that form with low level iceage oceans.
Ive read somewhere that for 80% of the time that Australia has been inhabited it was joined to New Guinea and Tasmania.
Aboriginal axe sharpening grooves,yengo national park.
This is a copy about Hatchets and knives taken from a book published 1914. I will add more from other books from different states and authors as i can.
Native Tribes of the Northern Territory of Australia
by Baldwin Spencer
Macmillan And Co., London
[1914]
STONE HATCHETS AND KNIVES.
At the present day it is not common to meet with stone hatchets except amongst the tribes in far outlying parts, and these are so wild that white men very seldom come in contact with them. For very many years past, the natives, partly through intercourse with whites, and partly, along the seaboard, through intercourse with Malays and others, have been well acquainted with the use of iron. Amongst the Northern Central tribes, we have previously described in detail the nature and manufacture of their stone hatchets, picks and knives, and, in all important respects, what we wrote concerning these tribes is true of those with which I am now dealing. As I have pointed out before, the terms Eolithic, Palæolithic and Neolithic have no meaning whatever when used in connection with culture stages or periods in reference to Australia.
The one thing that stands out clearly, is that the nature of the stone weapon, or implement, used by an Australian aboriginal is determined, primarily, by the nature of the material available. If he lives where he can secure only quartzite, or some such rock, then he makes chipped and flaked implements. These may be as crude as the crudest so-called Palæolithic implements, or they may be as beautifully and delicately chipped as the finest arrow heads found in European prehistoric collections. If he lives where he can secure diorite and rocks of that nature, then he grinds his stone implements and, if he lives where he can obtain both quartzite and diorite, then he makes flaked, chipped and ground implements, just according to what material lies handiest. It is no uncommon thing, or was not until the Northern Central tribes came into contact with foreigners, to find one man carrying with him, at one and the same time, a ground and hafted stone axe, a flaked pick, a flaked stone knife, and a few small, crudely flaked, or perhaps flaked and chipped stones. He might even have also a beautifully chipped spear-head and, at the same time, you would find him using in camp a stone that he had just picked up and roughly flaked to serve some passing need. sonic indeed, of their stone implements are so crude that, if found fossil, they would only be recognised as being of human manufacture by those who have had personal experience of the Australian aboriginal, and have actually seen him at work, and even then in many cases it would be difficult to be absolutely sure.
It is not, I think, too much to say that we can now, amongst Australian stone implements, find parallels for all the various types that have been described elsewhere, and the interesting feature is that they all exist and either now are, or until very recently have been, in use side by side.
Tribes like the Larakia, Worgait, Warrai and others have practically no stone weapons left. They use iron or, perhaps, if they do not happen to have a white man's knife or hatchet with them, they may use a flaked stone which is thrown aside as soon as it has served its temporary purpose.
Amongst the less contaminated tribes of the interior, hatchets, knives and picks are still met with, though, yearly, in decreasing numbers. Amongst the coastal tribes two influences have been at work tending to lessen the importance of stone cutting implements. In the first place the natives have, for long years past, secured a certain supply of iron hatchets and knives from Malays and others visiting the northern coasts of Australia in search of trepang and tortoiseshell. In the second place they have found that shells, such as a large species of Cyrena, very common on Melville and Bathurst Islands. make admirable cutting and scraping tools. The I result is that stone implements of all kinds are now comparatively rare.
On Plate XII. four specimens of hafted stone axes are illustrated which are interesting because of their crudeness. Figs. 1, 2 and 3 are from the Kakadu tribe on the Alligator River. In the first specimen the stone is evidently a naturally wedge-shaped pebble of diorite. It measures six and three-quarter inches in length, three in greatest width and, in thickness, diminishes from one and a quarter inches to three-quarters of an inch just above the cutting edge. The latter has been worked on both sides. In the second and third the stone is also a diorite pebble. The second has evidently had chips knocked off the side which lies to the right in the figure, and both surfaces, close to the cutting edge, have been ground to a slight extent. The third has one surface left in its natural condition, the one seen in the figure has been roughly worked and there is just a slight, but only a very slight, indication of grinding close around the cutting edge. In each of these three specimens, the handle has the form of a bent withy, passing round close to the wider end of the stone, which, together with the withy, is enclosed in a mass of beeswax.
Fig. 4, which came from Melville Island, represents the crudest hafted axe that I have ever seen in Australia.[1] It is simply a roughly shaped block of ferruginous sandstone, measuring six and a half inches in length, four and a quarter in width, and two and a quarter in greatest thickness. It has been very roughly flaked so as to reduce it to its present shape and to form, also, what must have been a very unserviceable cutting edge, but there has been no attempt at grinding. It is the only example, that I have seen in Australia, of a hafted axe which has been flaked and not ground. The withy passes
[1. Unless the extraordinary, roughly shaped little blocks of granite, hafted in resin and formerly made by certain West Australian natives, can be called axes.]
almost round the centre of the stone, to which it is I attached by kapei, that is a hard, brittle resin, derived from the root of the ironwood tree (Leschenhaultia sp.), the two halves being tightly bound together by strips of bark.
During their thousands of years of living in the rainforests of North Queensland, the Ngadjonji have acquired an intimate knowledge of the plants and animals which shared their world.
Link Weapons and Tools
As Quoted from the page link above.
"Stone axes were highly-prized and very useful tools for the Ngadjonji.
They were used mostly for woodworking - to cut out and dress the wood needed for making shields, swords, spear points and boomerangs and for removing the sheets of bark used for making blankets. They were not usually used for fighting. The stone axe head was ground to an edge at each end with a groove ground around the middle for the strap which attached the head to the handle.
The handles were usually made from the robust lawyercanes jungganyu or nidu. A strap of the handle cane was wrapped around the central groove in the head and bound in place using strips of yapulam or barrga. (See Lawyercanes 404 Not Found
A brilliant site with a wealth of information and pics in regards to the Ngadjoni people and a plant index of traditional names to modern names with uses and preparations.
Australian Aborigines by J. Dawson 1881
TOOLS.
The natives have few tools ; the principal one is the stone axe, which resembles the stone celts found in Europe. This useful and indispensable implement is of various sizes. It is made chiefly of green stone, shaped like a wedge, and ground at one end to a shai-p edge. At the other end it is grasped in the bend of a doubled piece of split sapling, bound with kangaroo sinews, to form a handle, which is cemented to it with a composition of gum and shell lime. This cement is made by gathering fresh wattle gum, pulling it into small pieces, masticating it with the teeth, and then placing it between two sheets of green bark, which are put into a shallow hole in the ground, and covered up with hot ashes till the gum is dissolved. It is then taken out, and worked and pulled with the hands till it has become quite stringy, when it is mixed with lime made of burnt mussel shells,
pounded in a hollow stone — which is always kept for the purpose — and kneaded into a tough paste. This cement is indispensable to the natives in making their tools, spears, and water buckets. The stone axe is so valuable and scarce that it is generally the property of the chief of the tribe. He lends it, however, for a consideration, to the best climbers, who use it to cut steps in the bark of trees, to enable them to climb in search of bears, opossums, birds, and nests, and also to cut wood and to strip bark for their dwellings. For the latter purpose the butt end of the handle of the axe is made wedge-shaped, to push under the sheets of bark and prize them off the trees.
The Aboriginal "Axe Factory"
A term coined by W.J Enright of West Maitland. The term describes an area where hundreds of grooves have been found. Most often this is in the bed rock of creeks or rivers. It was first documented officially by Enright in 1936. The site which prompted this term was a discovery by Dr G.D Osborne of the Department of Geology. He discovered a large set of grinding grooves in the bed of Green Wattle Creek in the Lower Paterson Valley. In less than a space of 200 square yards 160 places were found where axes had been ground. On the north side of the Woodville-Paterson road, near the bridge over the Paterson River between Tocal and Paterson another smaller site was also discovered.
Notes on aboriginal stone axe discovered in West Maitland, N.S.W. / by W.J. Enright [1911]
p. 269-270 ; 25 cm. National Library of Australia
A section of the large axe factory at Green Wattle Creek
The vastness of the Green Wattle Creek site suggests that is was used for a long period of time and also that the people camped in the area for prolonged periods due to axe grinding being a time consuming process. It is likely to assume that people in this area used axes as a trade item as other groups were unlikely to have such a suitable sandstone for grinding.
Shaped axe head artifacts. Note the tapering design which becomes rounded at the end. Also note the groove carved into rear of the axe showing where the handle would have been bound
The Small Axe or "mundabang"
The Wonnarua people used stone axes for many tasks these included but are not limited to making foot holds for climbing trees. butchering game, splitting logs to extract insects and peeling bark from trees to produce canoes or shields. The stone axe head was shaped in the axe grooves then a wooden handle is bound to the head with strong natural twine or animal sinew, most commonly kangaroo or wallaby. The head is fastened to the handle by using a resin such as treated resin from Xanthorea species.
Stone axe replica. Made by Roy Barker
[/quote]
So there's probably a long way top go yet before I get to the bottom of this whole "best axe" bidness that I seem to have gotten delved way into now. :rolleyes:
In for a penny in for a pound I guess. :lol:
nilla60
Unread post by nilla60 » May 14th, 2016, 8:13 am
This Youtube channel is amazing, he builds all kinds of stuff from scratch, including a stone axe:
https://www.youtube.com/watch?v=BN-34JfUrHY
Shann Low
Unread post by Shann Low » May 14th, 2016, 12:05 pm
Awesome effort that one - shows you pretty much exactly whats involved in the process - eh!.
40,ooo years of evolution & we haven't cracked the exploding / laser cutting axe in your Iphone yet - but we KNOW its just a question of time.!
I am already muddling away at:-
Altering an axe handle design so that you can hit rings at ground level with the axe head flat to the wood so the bit of the axe gets even penetration.
However,
https://www.youtube.com/watch?v=4D101Nf ... pPr3LFicWd
I am already thinking about a explosive version of the logomatic block splitter fired by those gas canisters & a peizo electric trigger / igniter mechanism from a Paslode framing gun that shoots a captive bolt wedge thru the ring of wood to split it.
A ramset type of log splitter if you will.
I even toyed with the idea of a blank .22 or .22 magnum powered one... however I suspect firearms laws here would require too much hassle with Police Firearms branch licensing, to make, sell, own, and use them, or buy ammo to fire them.
No problem firing blanks in one in the USA tho, where undoubtedly the biggest market would be to sell them.
Its a no brainer when you think about it.
Explosive axe.... it could catch on - take to to the shark tank or crowd fund it!
Who wants in with some shares? :lol: :D
nilla60
Unread post by nilla60 » May 14th, 2016, 5:36 pm
Ramset tools use little .22 style cartridges and as far as I am aware, they are not covered by firearms rules and regulations.
But... That .22-ish cartridge is usually used to drive a relatively small nail. The energy soaked up by a big lump of steel like a wedge would be substantial. For example, a .22 rifle weighs about the same as an axe, and the recoil of a .22 is barely noticeable.
Shann Low
Unread post by Shann Low » May 14th, 2016, 8:10 pm
Yes I hear you Nilla!.
Back in my day, as a lad working in the railways engineering dept looking after rail track etc we had what was called "Velocity Rail Punches" that drove a captive hardened "punch" clean thru the web of a 45 pound rail.
http://www.progressiverailroading.com/p ... nch--19628
These were powered by Blank US Govt 45-70 cartridges.
My ganger's used to keep the fired ones for me to reload as I had a old Marlin 45/70 lever action saddle carbine, back in those days.
So I am guessing for a US Market you could probably find a cardridge somewhere between .22 and 30 ought 06, that would have enough oomph to blow a wedge thru wood.
The old 45/70 use to kick like a mule at both ends... but if it will punch thru solid steel then a Jarrah ring should a walk in the park I reckon.
I still think that for here in oz probably a 9 kilo propane bottle with a long retractable hose mounted on front of your firewood trailer - connected to the gas splitter and a peizo electric ignition would get around all the firearms laws requirements... cheap to run and easy to refill, etc.
Just make the gas chamber big enough to deliver the energy to fire the wedge with enough force to do the job.
Trick will be making the splitter heavy enough not to recoil / bounce off the jarrah ring, rather than split it!
Spring loaded captive wedge so it reloads itself for the next cycle.
I think it could work tho if designed & proto-typed properly.
Imagine it leaning against the wall in your wood shed... yo could split 2 rings and put it aside - load the split wood in the barrow and have it in the house in 5 minutes without having swung an axe or block splitter once.
I just like the idea of blowing wood apart - probably watched one too many Mythbusters episodes where they blow stuff up I guess. :lol:
nilla60
Unread post by nilla60 » May 14th, 2016, 9:50 pm
If it's like that rail punch, no drama as no projectiles eject from the system. Say it works like a 2 stroke engine with the wedge on the piston and ports at the end of the cylinder to let the gas out before the piston/wedge gets shot into orbit? No projectile, no weapon.
For a trailer on the farm, the old man got the s**ts drilling holes and used a Ramset gun to nail oak planks into RSJ.
BTW, now thanks to this thread, I am now I'm looking at making new handles for my Billnäs axe and Hults Bruks shaping hatchet. Just need to source some well season spotted gum billets... Ohh, lookout, a local mill I know does custom milling of spotted gum. Now I know what I'm doing on my next day off. :D
Shann Low
Unread post by Shann Low » May 15th, 2016, 12:51 am
Spotted gum makes excellent axe & hatchet handles & looks the bomb with some boiled linseed oil left to soak in, then rubbed back.
Sadly I am no machinist/metal lathe fitter & turner.
I think with the weight of a splitting maul head and maybe some high speed filming of a decent axe swing one could probably work out the kinetic energy required to split Jarrah rings.
Up the margin by say 50% and it should be possible for a engineer type to work out what charge (volume) of LPG gas in what diameter and length chamber is required to drive a wedge of a known weight thru a Jarrah ring.
Course I am also no engineer. :lol:
What could possibly go wrong? :sillywink:
Shann Low
Unread post by Shann Low » September 24th, 2016, 2:07 am
Straight out of the Forge
After grinding and heat treating for harden & temper.
Assembled
Arrived!
Where it will get used.
What it is hoped it will produce.
We shall see in due course I guess.
4 months seemed like forever...
Now it's just a question of how it actually goes in practice on real hardwood Jarrah.
Shann Low
Unread post by Shann Low » September 26th, 2016, 7:27 pm
Early report is it chopped a ute and trailer load and was still so sharp you could shave with it!.
The advantage with it over a splitting maul is the edge is longer so the rings tend to split straight across when you hit them! The splitting mauls have a wedge style blade thas only a couple inches long - more like a chisel than an axe and when they split the ring, the split tends to follow the grain around in a big circle... & then you have to split those circles into blocks.
The Tuatahi having a much wider blade (~200 mm) means that you can split a ring in half straight across the middle with one hit.
So far pretty impressed!
Shann Low
Unread post by Shann Low » October 1st, 2016, 6:56 pm
For anyone interested, here's a short vid clip of the new Tuatahi work axe annihilating an old growth Jarrah hardwood firewood ring from a dead stag on private property.
https://www.youtube.com/watch?v=x-LamxA ... e=youtu.be
Hits like Muhammad Ali - a real one hit wonder!. :thumb:
nilla60
Unread post by nilla60 » October 1st, 2016, 9:27 pm
Wow, that's a gorgeous bit of metal there. Love it!
Do you have any issues with the handle taking damage from over strike?
For good measure, here's my double bit Gransfors:
Still just have an old Plumb in the car, this one is still on the mantlepiece except when we had a go at axe throwing.
Shann Low
Unread post by Shann Low » October 1st, 2016, 10:38 pm
I REALLY like that double bit Gransfors! :thumb:
Fantastic axe for felling and clearing tracks etc.
Yes over-strike definitely can and does, damage axe handles.
It occurs when you mis - judge the distance to the block your chopping.
The trick to avoiding over strike is not to misjudge the distance!. :lol:
But seriously the more you do of it the better you get at judging your distance.
Lad says this:- "I tried both the husqvarna splitter and the stihl splitter and the Tuatahi beat them both hands down".
Seems it's a winner.
Exploding axe next! :crazy: :eek:
typhoeus
Unread post by typhoeus » October 6th, 2016, 6:30 pm
Re your idea about an explosive powered splitter, Have you considered using the jackhammer principle? eg air powered splitter ? you could try making an axe head for a jackhammer and trying it out.
Shann Low
Unread post by Shann Low » October 7th, 2016, 5:45 am
Compressed air could indeed work. It is another option indeed!.
So a pneumatic axe!
Can't see why not!.
Hardly as much fun as blowing things up...but probably a lot safer! LOL
typhoeus
Unread post by typhoeus » October 7th, 2016, 8:27 am
Trust me, blowing things up can get you into trouble, especially these days. Sticks of geli behind the dunny doesn't go down as well as when Gelignite Jack was around!!
