Where can I get Recovery points for a VW Amarok?
Amarok34
Unread post by Amarok34 » February 18th, 2014, 9:08 pm
Does anyone know where you can get front recovery points for a Vw amarok
Temelj
Re: Where can I get Recovery points for a VW Amarok?
Unread post by Temelj » January 27th, 2015, 10:49 am
Hi,
There is a spot on front driver side. The bodykit has a little opening you have to take off the plastic part - just pull on it.
In there will be a tow point. The tow ring comes with the car.
http://img-2013.tapatalk.com/d/13/09/18/aqudy3u2.jpg
This has a bullbar and its clearly visible but it is in the same location.
On your rear driver side again you have one and its visible.
The other recovery point would be to take off your tow ball and snatch from there.
4wd Hobbit
Unread post by 4wd Hobbit » January 28th, 2015, 11:07 am
Temelj wrote:There is a spot on front driver side. The bodykit has a little opening you have to take off the plastic part - just pull on it.
That will be a tow point not a "rated" recovery point - tow points are not suitable for recovering a bogged vehicle just for towing the vehicle on the bitumen.
Temelj wrote:The other recovery point would be to take off your tow ball and snatch from there.
Never, never, never, never, never, never, never do a recovery from the towball - highly dangerous as they can snap off with a snatch and kill people.
djknemo
Unread post by djknemo » July 15th, 2018, 7:42 pm
HI
Not sure if you are still looking or not. I have found these
Wolf 4x4 in Queensland sell amarok recovery points they range from sway bar replacements to chassis mounted ones (need to mod bumper)
sway bar replacement (15 min per side) http://www.wolf4x4.com.au/ybob-volkwage ... ery-points Have these installed on my Amarok haven't got stuck with them fitted to test them out
Chassis mounted http://www.wolf4x4.com.au/roadsafe-reco ... gen-amarok
Return to “VW Amarok”
