LS1 powered 75 series
tim2117
Unread post by tim2117 » January 10th, 2015, 2:04 pm
this is my fzj75 95 model
has single tank.
rear tray light.
ipf spotties.
uhf
31" tyres on -22 offset 15" rims have 33x12.5 bfg muddies coming next month
have dual battery system to put in from hilux does anybody know where i can fit a second battery?
would like to add factory sub tank how hard is this? does it just bolt in or do i have to weld some brackets in?
will be getting rear e locker at end of financial year as rear lsd hasnt proven itself.
also fixed a steering knock so pulled out steering column and regreased universal joints and all good.
while i was there i replaced gearlever bush and replaced slave cylender to fix the grinding gears problem.
decided to fix surface rust in floor before it got out of control. grinded it to bare metal and painted over the top with sound deadner
mechanical work so far:
- repacked wheel bearings
- front pads and discs
- rear handbrake shoes, discs and pads
- front shock bushes
- rocker cover gasket and spark plug seals and replaced spark plugs
- resealed sump
- replaced crankshaft pulley seal and oil pump seal.
- replaced transfer output shaft seals.
- replaced front pinon diff seal
only oil leak i have now is from power steering pump. does anybody know if this can be unbolted from back of the block or u have to take it off the timing chain first as it is driven off timing chain?
- 1995 LSJ75 Landcruiser Ute My Shooting Rig
LS1 Powered 75 series
viewtopic.php?f=189&t=156317&p=1822747#p1822747
tim2117
Re: my fzj75
Unread post by tim2117 » January 10th, 2015, 2:10 pm
driving home from work someone in a mazda 626 sedan decided to pull out into the intersection just as i was coming past and
the cruiser didnt stop in time.
the mazda copped bent a,b,c frames doors, buckled roof, front and rear floors buckled. and probably alot more i didnt notice.
cruiser on the other hand copped a bent bullbar and a dent in lower guard where bullbar hit it and and dent in upper guard where uhf aerial mount hit it.
good outcome in the end as driver of mazda admitted fault and ill be getting a brand new bullbar at no cost to me.
tim2117
Re: my fzj75
Unread post by tim2117 » January 12th, 2015, 9:01 pm
tim2117
Re: my fzj75
Unread post by tim2117 » November 9th, 2015, 8:47 pm
A bit of an update built tray, sub tank, mud tyres, extended shackles, and lastly LS1 conversion goes like a rocket now.
tim2117
Re: my fzj75
Unread post by tim2117 » November 9th, 2015, 9:01 pm
Out with the old.
In with the new
All mounted up
Almost done
tim2117
Re: my fzj75
Unread post by tim2117 » November 9th, 2015, 9:04 pm
tim2117
Re: LS1 powered 75 series
Unread post by tim2117 » November 9th, 2015, 9:09 pm
Air box
PatrickB
Unread post by PatrickB » November 10th, 2015, 5:18 pm
looking awesome mate nice work
Not for highway use
Unread post by Not for highway use » February 14th, 2016, 6:10 pm
good job! What adapter did you use for the gearbox? Marks?
Wannabe hasbeen
Return to “Utes”
