1985 Ln 65 d/c Hunting Truck W/ build up pics
Ln65 pig rig
Re: 1985 Ln 65 d/c Hunting Truck W/ build up pics
Unread post by Ln65 pig rig » August 23rd, 2014, 12:36 pm
Was going to dynamat the floor on the pig rig but it's too expensive so I busted out the Shultz gun today. Pretty happy how it turned out.
Not to have a crack is un-australian... I fluke ***** daily!!!
PatrickB
Unread post by PatrickB » August 23rd, 2014, 5:01 pm
Come up good. What's the stuff?
Ln65 pig rig
Unread post by Ln65 pig rig » August 23rd, 2014, 5:12 pm
Sound deadner Patrick..Motorspray was the brand. Think it cost me 25 bucks for a 1ltr bottle which I thinned with turps 15%. Just made it too. I'm going under lining under the vinyl floor I've ordered so I didn't bother with two coats just loaded it up with one heavy coat.
PatrickB
Unread post by PatrickB » August 24th, 2014, 7:42 am
Motorspray... Cheers mate. I'm wanting some white stuff to repace the original stuff under the rear wheel arches on my rig so might see if it comes in white.
Ln65 pig rig
Unread post by Ln65 pig rig » August 24th, 2014, 7:54 pm
What your after mate is called "stonegaurd" and motorspray make it in white or black.. I spray mine gaurds in the black deadner for two reasons.. Black is easy to keep clean and the sound deadner will keep the hum of my 33's down... Win win in my books.. Maybe something for you to think about?
Ln65 pig rig
Unread post by Ln65 pig rig » August 31st, 2014, 10:24 am
Got involed today in getting some of the panels flat with primer and some panel beating tools
It's only first coat of high build... I'm pretty happy
Ln65 pig rig
Unread post by Ln65 pig rig » September 10th, 2014, 7:04 pm
Did a little more today on the pig rig. Since there's hundreds if thousands of these ln65's made id decided too change up my front grille to stand out a little more.
Started with this...Then with a cut or two with the air saw I've ended up with this
Need a bit more sanding and a coat of satin black and I'm calling it good!
PatrickB
Unread post by PatrickB » September 14th, 2014, 8:37 pm
hey mate bonnet come up good. will look tidy as.
Ln65 pig rig
Unread post by Ln65 pig rig » September 15th, 2014, 8:34 pm
Hey sport,
Yeah bonnet came up spot on after file sanding it. Had heaps of lows and highs throughout it. It's since changed again I added a scoop to it also right above where the turbo manifold will go. I've got this one photo of it with second coat if colour gojng on...
Ln65 pig rig
Unread post by Ln65 pig rig » September 23rd, 2014, 7:35 am
Had a couple of hours up my sleeve yesterday so I knocked out one of the rear doors and blocked it down dead straight. I've noticed most ln65's have the speakers mounted to the rear section of the door card? I've decided to make a spacer and mount it too the front half! What have people done it this situation?
Ln65 pig rig
Unread post by Ln65 pig rig » September 28th, 2014, 10:34 am
Finished the front grill change... Toyota Factory v's my version
Ln65 pig rig
Unread post by Ln65 pig rig » October 21st, 2014, 12:14 pm
Just had two weeks off work up in sunny qld with the family so nothing much has happened on the hunting truck.. Bought a buff on the sat I got home and decided to give it a quick compound cut..
Pretty happy with the result so far... The photo is second cut without any polish yet..
PatrickB
Unread post by PatrickB » October 24th, 2014, 10:19 am
Shiny.... Going to be tough taking it down a tight track for the first time haha
Ln65 pig rig
Unread post by Ln65 pig rig » October 24th, 2014, 6:42 pm
Haha yeah mate... I'll be filthy I've I dent or scratch it first bush trip out...even worse one of the rifles goes off and punches a hole in it... Maybe I'll just take the .22 and leave the win308 at home
Ln65 pig rig
Unread post by Ln65 pig rig » December 2nd, 2014, 10:18 am
Hey,
Works been super busy over the past month leading into Christmas so haven't had to much time for the 65... Got the rear of the cab scuffed back today and paint with some left over sound deadner... It will be top coated with the body colour in the end anyway...
Return to “Utes”
