Guss' VX 2016 200 Series - Mods Pics & more
Guss
Unread post by Guss » July 20th, 2016, 9:10 am
Stock:
Kitted Up:
Mods List:
TJM T13 front bar, TJM 12000lb Winch, X-Ray 220-C Series LED D/Lights, TJM Airtec Snorkel, TJM TJM Underbody Bash plates, Split Batteries-Optima D31 as Main/Starter & D34 as Aux using a Hersee Isolator, Provent200 Catch Can & 30 Micron diesel Pre Filter, UniChip with 5 Map settings, BRC Quad Breather kit, Redarc Tow Pro Elite, GME 3350 UHF & aerial, Mobile car kit & aerial, Outback Draw System & Half Barrier, MSA Drop Slide for the 40ltr Engle, power to rear inc. Anderson plug, BFG K02 A/T Tyres, Lovells GVM Upgrade 3800kg Suspension with airbags in rear inc. Kevlar Sleeves by Airbag Man.
Will post up pics as the build goes..
Guss ;)
viewtopic.php?f=187&t=160755
viewtopic.php?f=187&t=34585
Re: Guss' VX 2016 200 Series - Mods Pics & more
Unread post by BigDutchy » July 20th, 2016, 4:17 pm
Very very nice mate. You must be really proud of your new car!
Guss
Unread post by Guss » July 20th, 2016, 6:02 pm
Just happy that it'll allow me to keep out on tracks in comfort, rather than having to give off roading away.. So proud isn't the word more 'thankful"
Guss ;)
Shann Low
Unread post by Shann Low » July 20th, 2016, 6:40 pm
Gus who are you going to get to install your Redarc tow pro elite brake controller?
You MAY have to include an additional relay on your pickup wire from your brake lights is all!.
I've just installed one of the lower model Tow Pro that doesn't have the wireless blue tooth connectivity to the rear plug from the controller (I had to run a wire front to back) - however.... apart from that, it's basically the same unit your looking at.
The thing you have to watch for, is the sensors on these new computer controlled vehicles that monitor everything in real time.
IF the sensors pick up voltage drop in the bake lights circuit when the redarc brake controller - triggers from the brake lights circuit, as you apply the brake THEN the sensors can cause the computer that controls everything to throw codes, when you jump on the brakes - which you then need a scanner to clear yourself or take to Tojo for them to do it.
It's not unheard of for ABS light to come on (and stay on) for e.g.
The relay helps prevent the voltage drop when applying the brake and the redarc unit then activates the brake circuit (blue wires).
Just a heads up for you - in case your planning to do the install yourself is all.
The Redarcs come with a auto re set 30 amp fusible link kit (About $70) that you should run in your power direct to the unit wire from positive on your battery also.
Best of luck with it - I reckon the Redarc Tow Pro elites are probably the best on the market.. with the tekonsha prodigy RF being next best.
You do have to drill a 10mm & 3 mm hole in that nice new car dash for the Redarc controller knob tho (Hopefully you have a blanked off switch plate you can utilize). Make sure you put it somewhere you can see & reach quickly / easily to push in the event of a trailer sway situation.
The joys of modding a vehicle. ;)
Guss
Unread post by Guss » July 20th, 2016, 7:59 pm
Cheers for the heads up on that I'll print that out & hand it to the installer..
No I'm not installing the Tow Pro, yes have a blank in a handy position..
Guss. ;)
Unread post by BigDutchy » July 20th, 2016, 9:22 pm
Guss wrote:Just happy that it'll allow me to keep out on tracks in comfort, rather than having to give off roading away.. So proud isn't the word more 'thankful"
Guss ;)
Good on you! I am with you mate
Guss
Unread post by Guss » July 21st, 2016, 5:55 pm
Cheers BD ;)
Had the new Boots fitted today BFG KO2s went up a profile 285/65R18s:
Guss
Unread post by Guss » July 27th, 2016, 7:24 pm
Starting to come together nicely..
TJM Airtec Snorkel:
Redarc Tow Pro Elite:
Outback Draw system & 12Volt supply in progress:
Guss. ;)
Shann Low
Unread post by Shann Low » July 27th, 2016, 7:44 pm
Looking pretty swish Gus.
If your not comfortable out on the tracks in that there's something wrong! :thumb:
One of life's conundrums/irony's... bye the time your old enough to afford all the good gear for off roading, your body can't stand up to the rigors of off-roading/4wding & camping any longer!
There's no justice in this life!. :lol:
Guss
Unread post by Guss » July 27th, 2016, 8:13 pm
Hit the nail Shann.. I'm doing this so I can stay doing what I love, getting out on the tracks & looking Fwd to many years touring Aus on & off road towing our Off Road van.. ;)
Shann Low
Unread post by Shann Low » July 29th, 2016, 5:39 pm
We need a like button.
Sure that's been said a few times.
Needs a height adjustable hitch so you can set the van level when towing (probably?)
Or air ride/height adjustable suspension at the rear?
Load levelers do put weight back over the front wheels (thus tend to lift the rear so if you have a weight distribution hitch maybe you could get away without either height adjustable hitch or air adjustable suspension?)
Probably no point until you do your suspension lift/upgrade anyway coz things will likely just change once that's done.
Guss
Unread post by Guss » July 31st, 2016, 8:07 pm
Have an off Road van.. so as it'll be used off road weight distribution/level rides can't be used.. suspension will be beefed up & Air bags with Kevlar sleaves in rear coils by the time it's set up it'll be towing level ;)
Guss
Unread post by Guss » August 14th, 2016, 1:23 pm
Finished under the hood Friday. Repositioned the FlashLube Catch Can:
See later replaced Flashlube Catch Can with Provent200 :thumb:
Fitted the FlasLube 30 micron Pre-Fuel/Water separator Filter:
Removed both Start batteries & Replaced, Passenger side becoming Start/main using an Optima D31 cca900 & Drivers Optima D34 as the Aux. all through a Hersee Isolator.. Works a treat too!
Optima D31:
Optima D34:
Hersee Isolator:
Bar,Winch, D/Lights, Bash Plate, Suspension & Air Compressor over next 2-4 Weeks.
Guss. ;)
Unread post by Peter Aawen » August 14th, 2016, 2:02 pm
It's really getting there Guss! Lookin' good! :thumb:
Guss
Unread post by Guss » August 14th, 2016, 4:11 pm
It is mate, decided it wasn't going to be a slow build like the Paj was over 14 years :eek: Sue has given me the green light to get it all out of the way so we can enjoy it.. That's hook up & go whenever we can. ;)
