ln106 1989 hilux setting up for trips
hi-lux89
Re: ln106 1989 hilux setting up for trips
Unread post by hi-lux89 » November 29th, 2012, 7:57 pm
started the hilux today was running really good till i found a big pool of diesel under it ... when putting the turbo intake on i had cracked the fuel return rail when undoing the injectors :(
hi-lux89
Unread post by hi-lux89 » December 1st, 2012, 7:59 am
hilux is going :) time to go out and test it out and get a little muddy
hi-lux89
Unread post by hi-lux89 » December 1st, 2012, 4:05 pm
testing out the turbo ... needs lockers and a 2.5" exhaust other then that its pretty good heres some pics of today
Deans4by
Unread post by Deans4by » December 1st, 2012, 7:16 pm
Got some good flex there :thumb:
hi-lux89
Unread post by hi-lux89 » December 1st, 2012, 9:30 pm
yeh it has a bit as i said lockers will help me out alot
hi-lux89
Unread post by hi-lux89 » December 6th, 2012, 5:47 pm
need help with the fuel pump adjust ment have been told there is a screw some where on the pump witch adjusts the fuel wanting to know where this is and how far to adjust it
typhoeus
Unread post by typhoeus » December 6th, 2012, 7:38 pm
Hi, How about a snorkel for it? you said you sucked in some water before. there are lots of posts on how to make one on this forum, cheap to make and save yourself some trouble down the track!
hi-lux89
Unread post by hi-lux89 » December 6th, 2012, 8:58 pm
yeh thinking about making one with 3" exhaust tube .... atm im half thinking about buying a 2nd hilux off a guy at work pretty cheap and start from the ground up just need to find some more space to do it in it that or just buy it for the motor ( witch has only done 80000kms ) and get a few more bits off it and srap it .. snorkel is on the cards for sure but
typhoeus
Unread post by typhoeus » December 6th, 2012, 10:22 pm
If you did buy the other one, you could probably sell off anything you didnt want on here rather than scrap it. Im on the lookout for an old 3" alloy ladder rack to cut up and make into a snorkel, thus avoiding the narrowing of the pipe at the bends which you get with exhaust tubing. I have seen one made from alloy like this and it looks great.
hi-lux89
Unread post by hi-lux89 » December 7th, 2012, 6:45 am
just use welded in mandrel bends and smooth off the welds ... just chucked out a alloy ladder rack at work that got crushed by the fork lift on one end ... how would you get the 90deg bend coming out the side ???
typhoeus
Unread post by typhoeus » December 7th, 2012, 5:50 pm
Try lookin at some of these posts.
viewtopic.php?f=72&t=118016
viewtopic.php?f=76&t=116868
viewtopic.php?f=10&t=128400
it doesnt need to be exactly 90 degrees,as the rubber joiner from the air-cleaner to the snorkel gives you about 10-15 degrees of leeway. By Cutting the sections and getting them rewelded , you can adjust angles a little, But it depends on what you have to work with. Stainless is still good if you are able work with it, or get it done
EDIT: Ok found the link to a snorkel made from ally ladder rack
viewtopic.php?f=105&t=125880
hi-lux89
Unread post by hi-lux89 » December 8th, 2012, 8:40 am
looks pretty good but thing the Stainless one looks just as good
hi-lux89
Unread post by hi-lux89 » December 10th, 2012, 6:30 pm
wishing i had more room to work on this hilux maybe even a 2nd one
hi-lux89
Unread post by hi-lux89 » December 14th, 2012, 9:58 am
fuel pump adjustment done and it has made it go alot better only thing is it idles above 1000rpm now
hi-lux89
Unread post by hi-lux89 » December 14th, 2012, 1:05 pm
just got a little idea to make a alloy canopy/toolbox out of 2 alloy tool boxes here are some drawings to show what i was thinking of .... what do you guys think? anything i should add or take out ?
