Barrett 510 autotune antenna question
A.J.
Unread post by A.J. » April 18th, 2013, 8:54 pm
Hey guys!
I have purchased a second hand Barrett 550 HF radio with 510 autotune antenna.
My antenna did not come with the actual whip for it.
I have tried to find a place that sells the stainless whips but have had no luck so far :(
I have noticed that any 477mhz or CB antenna whip will screw onto the base without issue.
The ones you can buy from Supercheap for around $30-$40.
Will any whip work or will the performance not be up to scratch without the "proper" whip?
As far as I can tell it's just a piece of steel, the actual tuning but is in the base anyway.
If I could just order the "roper" whip, that would be ideal.
Thanks for your help!
A.J.
Re: Barrett 510 autotune antenna question
Unread post by A.J. » April 21st, 2013, 11:42 pm
Success :rolleyes:
I have just found and ordered a 2m stainless whip with spring base.
Took a while but it's sorted now ;)
puff
Unread post by puff » September 23rd, 2015, 10:20 am
Do you remember where you bought it by any chance. I am looking for the a HF stainless steel whip at the moment?
Return to “Communications”
