DIY Drop down fridge slide
zimmo
Unread post by zimmo » November 18th, 2014, 8:44 pm
Hi all,
Im currently Building a drop down fridge slide and have the issue the front of the slide is not coming up as high as the back when I lift it up to push it back in. Has anyone else had this issue and how did they fix it or did you just leave it as is.
BTUFF50
kevinmealing60
Re: DIY Drop down fridge slide
Unread post by kevinmealing60 » November 30th, 2014, 9:55 pm
Photos might help with helping you
85 60series 315/75r16 MT mtz on 16x10 sunnys
12h-t, front mount intercooled, 16 PSI boost, 93rwkw
beaudesert 3" mandrel bent, 3"suspension custom leaf packs,
superior extended shackles, air on board system.
Return to “DIY”
