Tube Notching Templates
outback cruisa
Unread post by outback cruisa » November 22nd, 2010, 11:00 am
Found this great site for those who are wanting to make some barwork, but dont want to fork out for a tube notcher.
Basically you put in the sizes of your pipe and it does all the work for you by giving you a template that you print out and cut to shape and it simply wraps around the pipe for you to mark and then cut/grind off to give you a nice tube notch.
http://metalgeek.com/static/cope.pcgi
Pathy Buildup: Project Pathy
4WDAction Issue 185 Full Feature
ollies
Re: Tube Notching Templates
Unread post by ollies » November 22nd, 2010, 7:49 pm
:thumb: thank you outback cruisa! that will be bloody handy
MOPAR or NO CAR
Unread post by MOPAR or NO CAR » November 23rd, 2010, 10:05 pm
Cheers for that mate, good website. This will do for the time being until I make my own notcher :waycool:
Massively Over Powered Asphalt Rippers
brooksy
Unread post by brooksy » November 26th, 2010, 6:19 pm
I call on saved files from this site on close angles where notcher is useless.
brooksy
0400 443 802
outback cruisa
Unread post by outback cruisa » November 28th, 2010, 12:57 am
hey brooksy would it be worth stickying this thread since its already proven to be a valuable tool?
brooksy
Unread post by brooksy » November 28th, 2010, 9:25 am
Why not .......... DONE !!!
brooksy
0400 443 802
mudshark
Unread post by mudshark » December 26th, 2010, 6:46 pm
G'day cruisa that's a great find thankyou I have printed out the template but am yet to test it out but it sure looks like it should work
cheers :thumb:
mudshark
Unread post by mudshark » December 29th, 2010, 10:02 pm
used the template it's easy as and works great
Dree Mon
Unread post by Dree Mon » March 24th, 2011, 7:18 am
When I did my roof rack I used my drop saw with it set on 22.5 for 2in round tube and made 2 cuts for each end, was a little fiddly to get it even to come up square , just leave a little extra length on the pipe for adjusting,
I made it square with a centre support and 50mm mesh under it
I'll try to get a pic of it up
lynch
Unread post by lynch » April 10th, 2011, 8:34 pm
thank you exactly what i needed !!!!!!!!!
boydey
Unread post by boydey » April 11th, 2011, 9:39 pm
Awesome site mate, wish I had known of this three years ago when i built my rock sliders, I just kinda guessed my way along
mick60turbo
Unread post by mick60turbo » July 18th, 2011, 6:37 pm
Awesome work guys! :waycool:
Having this site will save a lot of time.
Thanks :drink:
ken39
Unread post by ken39 » November 10th, 2011, 9:56 am
awesome thanks
rimshot
Unread post by rimshot » December 5th, 2011, 4:57 pm
Hi all , something I also use is PVC and poly pipe ???? OK get some pvc and or poly pipe and drill them with a hole saw. If you join say a 25mm to 50mm then you would use a 50mm hole saw to cut the 25mm pipe. then you slide the pipe over the steel pipe you like to cut and mark around it. By doing it this way you can keep it in the tool box and make any size you like.. Give it a go
Squiggs351
Unread post by Squiggs351 » January 30th, 2012, 9:55 pm
will be handy for TIG welding joins but for MIG i just cut a 45 on both sides with 1/3 of the diameter still square on the end. does a pretty good join.
LN106 Hilux D/C,EFI 5Litre and 4L60E, 2" spring lift, 2" body lift, 33x12.5 muddies, custom snorkel, custom tube winch bar.
BUILT... NOT BOUGHT...
