right hand wheel scrubbing on my hj45 landcruiser?
Greavesy4X4
Unread post by Greavesy4X4 » November 13th, 2015, 8:38 pm
i need some help i just fitted new 33" bighorns to my hj45 it has no lift on it and the right hand wheel is scrubbing on the steering linkage arm when i turn right. how can i fix this? do i need to lift it im not sure? please help
TheBlackbird
Re: right hand wheel scrubbing on my hj45 landcruiser?
Unread post by TheBlackbird » November 13th, 2015, 9:16 pm
Hi mate,
Welcome to the forum. A 2" lift would fix the scrubbing, considering you've got a HJ45, it's suspension could be pretty worn so replacing it is also good for reliability. Reliability is also a great selling point to the missus (accountant) :lol: :lol:
:fish:
1990 HJ75RV
Rogers Cruiser
Unread post by Rogers Cruiser » November 13th, 2015, 10:24 pm
Hold on,
If the tire is scrubbing on the steering arm then you will need wheels with a different offset.
-22 or -25mm wheels will fit 33 inch tires that are 12.5 inches wide.
You dont need a lift to run 33" tires, standard is roughly 32 inch.
Greavesy4X4
Unread post by Greavesy4X4 » November 14th, 2015, 10:52 am
which would be better -22 or-25?
Greavesy4X4
Unread post by Greavesy4X4 » November 14th, 2015, 10:59 am
would -23 be ok??
Rogers Cruiser
Unread post by Rogers Cruiser » November 14th, 2015, 11:48 am
Yes -23 would be ok, But I dont think Ive seen those before on steel wheels.
-25 would be my choice but then you will need to cover the 15mm of tire that hangs out past the guards.
Greavesy4X4
Unread post by Greavesy4X4 » November 14th, 2015, 2:14 pm
would it be ok to just do the front 2 tyres and leave the back normal?
Rogers Cruiser
Unread post by Rogers Cruiser » November 14th, 2015, 3:34 pm
No it would not be ok,
It would make driving the vehicle potentially unstable
even ignoring that
What if you get a flat tire?
Your tires and wheels should all be the same size, if not the same type.
Greavesy4X4
Unread post by Greavesy4X4 » December 6th, 2015, 9:01 pm
i can get -23 steel rims off ebay for 80 bucks?
Rogers Cruiser
Unread post by Rogers Cruiser » December 6th, 2015, 10:22 pm
yep!
They arnt expensive, you should be able to get them from a tire shop for <100$
Return to “Wheel and Tyre”
