ARB Diff lock switch, can I swap unused fr switch to winch?
wombats80
Unread post by wombats80 » February 26th, 2017, 11:24 pm
Can anyone point me to another thread or post here for what i need to do; i have a rear arb air locker locker & compressor but back in the day i installed it, i opted for the 3 switch panel assembly, presuming i'd eventually instal a front diff lock. That hasn't happened but what has happened is i've invested in a warn hi-mount winch upgrade which uses an additional solenoid arrangement to unlock the winch spool from the winch gearbox, meaning in even non comp conditions, my nav can run faster than ever before in recorded history. That wont happen but what i need to happen is how i can activate the compressor & not have to engage rear diff lock before turning on the front diff lock rocker switch which is now the disengage button for the winch drum, but without running new cable through the firewall. For the moment everything works fine but i got to have rear diff lock switched on 1st. What wires do i need to switch at the panel?
Return to “Electrical”
