08 Hilux heater/Air Con Fan not working - any advice?
Get your electrical juices flowing - ask those auto electrical questions here
nrj85
Unread post by nrj85 » March 16th, 2018, 5:06 pm
Hey crew!
So came out of work this arvo and found my air con fan no longer works. It's been making a very soft ticking noise over the last few months but still worked perfectly. Even on the drive to work this morning it was working well. Fan speed adjustment worked fine and the air con was cold as a fridge. Any ideas? I've checked the fuses.. all good. I've cleaned out the cabin filter and checked the fan still spins... I'm hoping it's something simple.. in fact, even just a stuffed fan would be ok. I just don't want to go replacing stuff if it's not the problem.
Any advice would be much appreciated.
Cheers!
Re: 08 Hilux heater/Air Con Fan not working - any advice?
Unread post by mydmax » March 22nd, 2018, 11:17 am
The aircon fan is the one in front of the radiator, the blower fan is the one inside which has to work for forced heat and/or cool airlfow. If all was ok previous and now the fan inside is not working, there are a number of possible reasons that could be why. Blown fuse? Faulty switch? ???
Return to “Electrical”
