Any fixes for a Stripped thread on HJ60 caliper mount?
dingocountry
Unread post by dingocountry » June 28th, 2016, 5:33 pm
Hi people, just finished rebuilding my hubs and brakes on HJ60 and found stripped thread in hub where caliper bolts on. Any ideas. I was thinking heli-coil. Would it be strong enough for this application? Any input greatly appreciated, thanks.
Dingo Dave
Neat 60
Re: Any fixes for a Stripped thread on HJ60 caliper mount?
Unread post by Neat 60 » June 28th, 2016, 9:00 pm
I wouldn't trust a helicoil on a brake caliper.
I'm pretty sure that bolt is M14. I'd drill it out and tap a thread for a high tensile M16 bolt.
If you're not confident in doing something like that I'd recommend calling someone like the Thread Doctor.
NZ LUX
Unread post by NZ LUX » June 29th, 2016, 9:59 am
Brake caliper bolts are under shear loading, not tensile, so essentially all that bolt is doing is holding the caliper in place. The braking forces are acting against the sides of the bolt.
fitting a helicoil would be ok, or if room allows, completely drill out the buggered thread and fit a longer bolt and nut to hold it all together
dingocountry
Unread post by dingocountry » June 29th, 2016, 11:58 am
Calipers are brand new so I am reluctant to go M16 as I would have to drill out hole in caliper. No clearance to fit nut behind. Thanks for the input so far. Keep the good ideas coming!
dingocountry
Unread post by dingocountry » July 15th, 2016, 3:39 pm
Thanks for the input. Went with a powercoil for practical reasons. Will let you know if it fails.
hoyks
Unread post by hoyks » July 15th, 2016, 4:10 pm
I would have no issue with a helicoil.
I have replaced them where they are standard fitment inside jet engines and on safety critical aluminium components.
The thread is often times stronger than the thread cut in the parent metal (particularly into aluminium) and you can get specialist inserts that have a deformed section in the middle so they are vibration resistant.
dingocountry
Unread post by dingocountry » July 15th, 2016, 4:18 pm
Just used a standard helicoil but i am confident it will hold. Didn't think of vibration at the time. Fingers crossed.
hoyks
Unread post by hoyks » July 15th, 2016, 6:53 pm
The locking thread ones are a pain in the arse to install and would be overkill for that job. As long as it is torqued up correctly, then it should be fine.
Return to “Drivetrain”
