Will '84 Hilux rear axles fit in a '97 Hilux live?
wooduck
Unread post by wooduck » December 10th, 2013, 7:47 pm
Will 1984 hilux rear axels fit in a 1997 hilux live
oversite
Re: Will '84 Hilux rear axles fit in a '97 Hilux live?
Unread post by oversite » December 10th, 2013, 10:11 pm
yep,
oversite
wait. . . . . . . assuming its an early '97 with a solid front axle. If its an IFS they might fit but I dont know!
wooduck
Unread post by wooduck » December 11th, 2013, 10:20 am
Yes its a solid axel both ends. Thanks for the help. Also could I run a 1 pice axel from a 60 series cruiser
oversite
Unread post by oversite » December 11th, 2013, 10:24 am
no the housings are totally different
you could replace the entire rear diff assembly, but that would require engineering (In NSW at least)
Return to “Drivetrain”
