LN106 Hilux Getting hot - what else to look at??
From your gearbox to your wheels - tech on drivetrain mods inside
australux
Re: LN106 Hilux Getting hot - what else to look at??
Unread post by australux » February 27th, 2014, 6:13 am
Residual casting sand in water jackets ?
You might see some grains of sand in the coolant when you first crack the radiator drain plug.
Hope this helps.
SimHilux
Unread post by SimHilux » March 30th, 2014, 9:18 pm
bump,
Taubdog, Im interested in wether you managed to fix the Hilux cooling problem. Was it the oil cooler behind the oil filter after all that ??
dirtfix
Unread post by dirtfix » February 7th, 2017, 2:03 pm
Sorry to resurrect an old thread but I am suffering the same problem. Found this link which is what I will be trying next...
http://neuralfibre.com/paul/4wd/tuning- ... fan-clutch
Drive it bro!!!
dirtfix
Unread post by dirtfix » February 7th, 2017, 2:11 pm
Drive it bro!!!
Unread post by mydmax » February 8th, 2017, 11:49 am
SimHilux
How can an overheating problem be the result of an engine oil cooler?
Does the vehicle have bigger tyres?
Although the injection timing marks are used to set the injection timing, are the marks really correct?
Although a new thermostat is fitted does it have the full size opening and does it really open fully at the stated temp? Many things to check before doing others.
Always double check the simple things first.
Return to “Drivetrain”
