One piece tailshaft Hilux
4x4 ewok
hilux one piece tailshaft
Unread post by 4x4 ewok » January 24th, 2009, 3:35 pm
The center bearing in my 106 is shagged and I am trying to decide which path to go down. Replace the bearing or replace the tailshaft with a one piece.
I have done quite a bit of searching on the subject both on here and outers, and there seems to be a fairly even spread fore and against. However most of these posts are a few years old so I am looking for peoples more recent opinions.
Just for a bit info it is standard height at the moment but I am going to being putting a 2in. lift in her in the not to far distant future. I am also tossing up the idear of a body lift as well but haven't decided on that one yet.
At the momentI am leaning towards going the one piece.
For those of you who have gone down the one piece option, have you just had a whole new shaft made, modified the existing one or modifed a tailshaft out of another vehicle.
beaujest4
Unread post by beaujest4 » January 25th, 2009, 12:04 pm
Be interesting to hear the replies. Done 3 or 4 centre bearings in about 2yrs now. Last one is a Toyota original but its not going much better.
Cheers Al
Do everything twice, just in case you got it wrong the first time
Captain Cupcake
Unread post by Captain Cupcake » January 25th, 2009, 2:35 pm
I have had my 1982 RN46 model Hilux (with a straight through drive shaft) since 1996 and except for having to get the shaft straightened, I have had no problems yet:)
[align=center][align=left][url]http://www.fluoridealert.org/[/url]
[url]http://www.themotleycrew.info/[/url] [url]http://www.nblc.com.au/[/url][/align]
[/align]
thomasshaw
Unread post by thomasshaw » June 20th, 2011, 7:10 pm
i have a ln106 diesel hilux and am looking at putting a one piec tailshaft in it.
i have heard that a lancruiser shaft will fit straight in not sure if its true but if so what series? thanks guys
destructalux
Re: One piece tailshaft Hilux
Unread post by destructalux » June 4th, 2012, 7:59 pm
anyone?
destructalux
Re: hilux one piece tailshaft
Unread post by destructalux » June 4th, 2012, 8:01 pm
not much replys :(
xj33
Unread post by xj33 » June 16th, 2012, 4:09 pm
just put a one piece shaft in my hilux .wish i had done it earlier. drives great now ,i had replaced 3 center bearings in the past 18 months
nyveld
Unread post by nyveld » January 4th, 2016, 5:25 pm
sorry to bring up old thread; but what shaft did you use to replace it? Or was it a custom shaft made? (I am having the same issue after 2" lift)
dod28
Unread post by dod28 » January 5th, 2016, 9:54 am
I had a custom shaft made for mine, don't know of any shafts that that are a straight swap
Return to “Drivetrain”
