LN106 2" lift toughdog springs - how do I fit them?
xgrumpig
Unread post by xgrumpig » October 7th, 2015, 4:06 pm
in process of replacing my front springs in my ln106.
it orginally had 2" ome wich im in process of replacing
i currently have one side out and new springs in and attached to the rear shackle and located in the diff but its a long way back off matching up with the front hanger do i need to do both sides then move the diff forward while attached to the springs or take them out again and attached the springs to the rear shackle and front hanger and then try move the diff forward to line up with the locating holes?
1997 Ln106 Trayback
Au falcon ghia seats
2" toughdog up front new
2"load carrying old man emu in the rear
2"body lift
33's
soon to be fully engineerd.
http://www.4wdaction.com.au/shed/classi ... -rockyscat
Gary_M
Unread post by Gary_M » October 7th, 2015, 4:23 pm
NVM, I may have read it wrong, I didn't notice fronts?
Note: Ive not done a Hilux.
EDIT:
Mount the eye end, mount the shackle, mount the diff. No weight on springs until mounted front and back.
If that doesnt work, mount shackle, then eye, again no weight. and might need a lever to line up the eye bolt. I would think it shouldnt be hugely difficult though. If it is, theres likely something wrong such as wrong spring.
Does the diff mount above or below the spring on a lux?
xgrumpig
Re: LN106 2" lift toughdog springs - how do I fit them?
Unread post by xgrumpig » October 7th, 2015, 5:03 pm
cheers will give that a go tommorow iv done it opposite to wat you have said and only one side at the momment. will post my results tommorow
cheers again.
1997 Ln106 Trayback
2"body lift
33's
xgrumpig
Unread post by xgrumpig » October 7th, 2015, 11:53 pm
"Gary_M
Below it spring over
I an get front n backm mounted easy enough its lining up the bolt with the locator hole its a good inch backwards.
Getting a trolly jack later today will try both new springs in and try move the diff
1997 Ln106 Trayback
2"body lift
33's
xgrumpig
Unread post by xgrumpig » October 8th, 2015, 9:00 pm
Thanks for the help springs are just about all done.
1 more ? How do I set my adjustable tourqe rod( diff locator) to the right setting. Cheers again.
1997 Ln106 Trayback
2"body lift
33's
Return to “Suspension”
