87 hilux rear springs hard as - which to remove?
chrome
Unread post by chrome » November 19th, 2013, 5:43 pm
hey all, iv got this 87 hilux that was set up as an farm truck, it sits high as in the back and since ive pulled off the ton and a half of deck off it and made a new lightened model it now bounces around corners at higher speeds.
now I know you can remove leaves and all that but which ones????
can someone have a looksie and suggest where to start please
thanks
6 leaves and 2 overloads
something tells me that i need to pull the 5th one down from the top for a start??
whizzo
Re: 87 hilux rear springs hard as - which to remove?
Unread post by whizzo » December 12th, 2013, 9:25 pm
Mate #1 thing to do is replace the shockies.
Hiluxes depend heavily on shockies......when they are buggered they ride like a dray.
New shockies and good ones.
They also ride like a dray empty too.....this is why lots of cockies fit heavy steel trays.
They realy do ride better with a bit of weight in the back......a decent tool box and a few goodies will solve that one.
If that is a heavy spring pack that has been fitted, maybe go back to a standard spring pack.
BTW I don't like the look of that handbrake cable rubbing on the top of the spring pack.
If ya dead set on removing leaves......a picture of the whole spring pack would be helpfull.
chrome
Unread post by chrome » December 13th, 2013, 3:25 pm
hey thanks for the reply,
In have pulled out two add a leafs from each side, I lost an inch of height and now the cable clears no prob.
a new set of shocks is coming and if I need too I can always add one add leaf back in if its got too much sag with a load on,
it def feels better now tho
Return to “Suspension”
