Newb to the off-road scene.
Don't be shy, say g'day in here - tell us a little about yourself, your 4By, & what you've done/dream about doing in it, only do post us a link to your Member's Rides thread too!
Nic_A31
Unread post by Nic_A31 » November 19th, 2017, 7:11 pm
Hey guys, long time car enthusiast, new to the 4x4 scene.
Have been mucking around with imports for about 8 years, recently moved from Perth to Canberra region.
I impulse purchased this in Melbourne around May (I think), and just barely made the drive home with it.
Got it for a crazy killer price, mechanically it was close to stock which is how I prefer to start a build.
Been throwing money at it here and there.
I'll throw up a build thread if you guys are keen to see it.
Good to finally be on the forums....been trying to join for ages :lol:
Re: Newb to the off-road scene.
Unread post by Peter Aawen » November 20th, 2017, 9:32 am
We are always keen to see build threads Nic, especially those that are of the 'less frequently modded' vehicles like yours! :thumb: And welcome aboard, sorry it took you so long to get on but there was a while there where the Forum wasn't up for handling much/many things... including new members :rolleyes:
But now the new & upgraded Forum is with us, hopefully that won't be a problem anymore!! The IT wallah who made the upgrade happen has worked VERY hard to resolve all the known issues & we've now got a bigger'n better Forum just ready to serve us well for the next decade!! AND he's hanging around to keep an eye on how it runs, altho he's also looking after a bunch of other EMG sites too, so there might be times when he's got other priorities - but this one is looking pretty robust so far! ;)
cuzza_wa
Unread post by cuzza_wa » November 20th, 2017, 4:16 pm
had one of these bad boys when i was much younger.
2'' lift on it, long shocks and could dissappear a 31'' muddy right up the back wheel guard.
Got it lots of places people never thought it could go, but careful winding up the torsion bars, i broke the front control arm twice coming out of steep climbs heavy footed due to no travel (rookie mistakes!)
still miss the seats on it, were so comfy!
Nic_A31
Unread post by Nic_A31 » November 21st, 2017, 1:02 pm
I'll chuck up a build thread :D
What's the reason for winding up the front torsion bars?
I see a lot of guys doing it, but not really sure why..
The seats are pretty comfy :D
cuzza_wa
Unread post by cuzza_wa » November 21st, 2017, 4:36 pm
i think (dont quote me) winding them up is a cheap way for some extra lift, but when you wind them all the way up you essentially take out all the up-travel or spring tension, so they become pretty stiff / bouncy.
Seriously, its one of the comfiest 4x4's i've had the pleasure of sitting in. id die for a set of those seats in the luxy haha
Unread post by Peter Aawen » November 21st, 2017, 4:48 pm
Many people think that winding up the torsion bars will give them a suspension lift on their torsion bar IFS vehicles along the lines of bigger coils or flexy leaves.... :cry: There's no denying that it does give them a higher static ride height - it does so by effectively moving the arms closer to one end of their arc of travel & resticting the range of flex/movement remaining available that way (often dangerously so) & yet leaving them most of their suspension travel left the other way.... the 'not helpful' way; but it doesn't increase their total travel at all and it can severely stress the CV's to the extent of destruction if the driver happens to ask them to turn & flex at the same time, or sometimes they just pull right out for the helluvit because their operating angles are waaaay too compromised!!
So while it CAN be a cheap way of gaining a LITTLE lift, you really shouldn't EVER lift a torsion bar IFS front end more than a max of about 40mm - the only real way to achieve a bigger lift is either modding/lengthening the arms &/or changing the pivot points on the chassis end... just about anything else is just gonna be changing the static ride height & moving the arc of suspension travel coser to one set of bump stops or the other (depending upon which design IFS the vehicle has! :o
Return to “Introductions”
