Might sticky this one
http://www.infrastructure.gov.au/roads/ ... 1_ver5.pdf
NCOP - building small trailers:- VSB 1 Revision 5, June 2009
- Part of the furniture
78 BJ40, 4" lift, 33's
82 HJ60, 4.5" lift, 33's
09 ML Triton GLXR, 3.5" lift, 32's
- Getting to know the place
Axles, solid or hollow?
Interesting that, nowhere does it say (that I could see), that a trailer must have a solid axle...
I made mine with a 60 series rear axle cut off at the ends, welded to a length of heavy wall 80NB pipe and sleeved internally.
The brakes can be either hydraulic, or as I used, cable override.
It has stronger bearings than most trailers, massive drum brakes and spares are available almost anywhere.
- Need to get out more
In the past, some of the state governments banned the use of welded or plated stubaxles..
But these days they are more interested in laying responsibility.
And this is the important thing to understand.
If you are going to build a trailer, YOU are responsible for the engineering of that trailer for the life of the trailer.
If something you do breaks....it is your fault.......and you will be expected to justify both the engineering decisions and calculations and the workmanship, should the matter come to court.
OR more importantly should an insurer persue you for their costs.
NOW
on the self assessment of light trailers form, we fill in in QLD, you are required to specify the load rating of some specific components...how do you derive those figures fom a backyard welded stub axle assembly.
If you buy an axle or suspension system, the load rating and the liability for engineering the items lies with the manufacturer.
These days we live in a world where they will simply rubber stamp all sorts of things....and all is fine untill something goes wrong...then it gets very uggly and expensive.
NOW
- Been here a while
Re: NCOP - building small trailers:- VSB 1 Revision 5, June
the above link no longer works the new link is
http://www.infrastructure.gov.au/roads/ ... index.aspx
or
http://www.infrastructure.gov.au/roads/ ... ne2009.pdf For PDF
or
