Stretch4x4 I thought so as well, the suspension now is still up,
the compressor still might need a upgrade in the future, so you know where I will be buying that.
Now the roof is off I have started to work on the fittings and the lining. All six overhead light brackets have been fitted as well as the holes through the frame to run the wiring.
I have also made a bracket in the two back corners to carry the strap for the wiring to travel up and down with the actuators.
Then the fun started, the ceiling panels had to be flexed into place, as they were a tight fit. Once in they were not coming out again.
I still have the narrow wall sections to finish before turning the roof over to fit the single roof sheet in place.
