My scratch built 40 series trailer. ( project TOW40 )
croozy
Unread post by croozy » September 29th, 2013, 11:27 am
I've been trying to get around to building myself a trailer for a while now. I wanted something a little different, so I've decided to make one that is the same shape as my 40 series. It will be used as a trailer but will also be used for camping. I already have a Trek camper but will be selling it before too much longer as it doesn't get used as much now due to work & also my young bloke had a pretty huge spinal op this year which has changed the way we will camp when we get the chance. It will also serve as a luggage area when we go away because the shorty isn't big on space once we're all in it.
I put some pics up in my car's buildup thread but thought I put it in here under it's own buildup..
So what I started with was some 20x20x2mm square section for the framework. I had it bent up but the guy that bent it didn't get the size right so I had to cut up the frames & weld them back together. I made a table to start with so I had something to work on. Then I screwed to timber to the table to make a jig so I could make sure the bends were at right angles.
Clamped to the jig.
welded braces over the corners to kep square.
After both frames were welded & squared up I cut some uprights & tacked them in. I made it high enough to be able to fit a fridge in it.
I then welded some more bars in the frame. These will give me something to fix the sheet work to as well as the guard flares.
HAVE A GANDA AT MY SHED
croozy
Re: My scratch built 40 series trailer.
Now time for a bit of a mock up at ride height.
I have two fibreglass turrets to cut up to make a hard cover as well so once the body is done I will be making that.
oversite
Unread post by oversite » September 29th, 2013, 1:03 pm
looks good, Whats the plan with it? is it just luggage area under the roof? or are you planning something more complicated?
croozy
Unread post by croozy » September 29th, 2013, 3:41 pm
Thanks. I'm going to make a drop in section that will incorporate a fridge slide and other stuff. I will also reinforce the hard cover so I can mount a rack on it too. The tail gate will swing out so I can put a drop down table on it. Other stuff I'll decide on as I go.
WomblingFree
Unread post by WomblingFree » September 29th, 2013, 5:06 pm
Is it just a trailer with a lid or a camper with a tent on top?
croozy
Unread post by croozy » September 29th, 2013, 5:12 pm
It will be a trailer with a hard cover & I am going to buy a couple of OZTents to camp out of. The trailer will carry all the camping gear though.
croozy
Unread post by croozy » October 1st, 2013, 4:36 pm
I got a couple of hours spare yesterday so I bought some more steel & made the floor braces.
I took it outside to see what it would look like with the cruiser.
And this is the sort of thing I'm aiming for.
oversite
Unread post by oversite » October 1st, 2013, 4:39 pm
Yeah that does look cool. are you going to use a 40 series diff for the trailer so you ahve the same track and clearence ect?
oversite
And are you plannning to add some chasis like rails for the trailer?
croozy
Unread post by croozy » October 1st, 2013, 5:33 pm
Yeah it will have the same track as the 40, but I will just make up an axle. It will have a full independant chassis & the body will bolt onto it. I have a set of 40 series springs that were in my car a few years ago, so I'll use those under it too.
Unread post by THE RIG » October 1st, 2013, 8:54 pm
great concept, this will look awesome, watching this build for sure!
croozy
Unread post by croozy » October 3rd, 2013, 5:45 pm
Thanks mate. I'm trying to get stuck into it because work is starting to get busy & come Xmas I'll have no time to work on it.
monkeybucket
Unread post by monkeybucket » October 3rd, 2013, 11:39 pm
This is awesome.... keen to see it finished champ. Might be a market for it...
Chris.
edz
Unread post by edz » October 4th, 2013, 9:04 pm
Nice rig and trailer Croozy [ is that a fibre glass body on the truck ? ].. looks like you have been trawling Expedition portal and Ih8mud sites too !!
Those Yanks have some diferent gear to what we are used to ..
" WE GO WITH WHAT WE'VE GOT "
croozy
Unread post by croozy » October 4th, 2013, 9:37 pm
Thanks edz. Only the front end is glass, & yeah I've been a MUD member for a while now. I also frequent the Pirate 4x4 forum too. I wish we could get our hands on some of the stuff they have over there easier.
Return to “My Camper Trailer”
