Front tube bars
dattopimp
Unread post by dattopimp » November 21st, 2007, 9:13 pm
2.something weeks at the powder coaters and its finally back. All up cost less then $200 to make. And i'm happy with it :)
And yes i know it doesn't really count as a tube bar...But oh well. Maybe next time.
87 MK Patrol. 2" OME + 30mm body, 31" ATZs on alloys/35" Simex ETs, dual ARB lockers, 12,000lbs winch in custom bar, Doof doof. Need more money!
locorr
Unread post by locorr » November 21st, 2007, 9:46 pm
Is that for the datsun
mudntz
Unread post by mudntz » November 23rd, 2007, 9:46 pm
heres a pic of a tube bar i built for playtime 4x4,
not bad for a 1st year fitter and turner.
tube used is 48.3mm, 2.9mm wall thickness
SLOW AND STEADY WINS THE RACE
dattopimp
Unread post by dattopimp » November 24th, 2007, 5:23 pm
thats not a bad job mudntz, and locorr yeah its for the datsun patrol :P
mouse
Unread post by mouse » November 25th, 2007, 7:20 pm
Here's some photos of an mk tube bar I just finished for Playtime 4X4 in Sunbury. Just needs powdercoatng. The Hilux bar was done by my apprentice (Mudntz).
gutlux03
Unread post by gutlux03 » March 15th, 2010, 8:34 pm
hey mate just wondering where you get your designing software from can ou download it for free or do u have to buy it
Pr.J.Chilton
Unread post by Pr.J.Chilton » March 16th, 2010, 5:24 pm
here's mine
not really a tube bar but the top half is custom tube work(@ least I've got a good approach angle)
Struth
Unread post by Struth » April 6th, 2010, 9:57 am
mouse wrote:Here's some photos of an mk tube bar I just finished for Playtime 4X4 in Sunbury. Just needs powdercoatng. The Hilux bar was done by my apprentice (Mudntz).
Your apprentice does better work than you do:crazy:
Struth
Unread post by Struth » April 13th, 2010, 7:35 pm
I have never used CAD or any other software to design a bar.
The ones I have built probably took me up to 8 hrs each including coating time.
But not including design and hand drafting time, or the time it takes to get the cradle bent up by the local metal shop once I give them the drawings.
Here are two of mine,
Both were made in my garage with no real industrial machinery. They are not hard to make if you are an experienced metal worker.
madazz fab
Unread post by madazz fab » April 28th, 2010, 1:21 pm
here are 2 i have made the second is in the build
whitelighting
Re: Front tube bars
Unread post by whitelighting » July 10th, 2011, 6:52 pm
Something a different that I built.
HG
Re: Front tube bars
Unread post by HG » July 17th, 2011, 10:05 pm
I made this bar about 7 years ago, it has done a great job :)
Sim79
Re: Front tube bars
Unread post by Sim79 » July 31st, 2011, 8:17 am
zook2412
Re: Front tube bars
Unread post by zook2412 » April 3rd, 2012, 6:08 pm
i knocked my own up , it wasnt finished then , it has bracing from behind to the bends on the side and also bracing from the mounting plates up to the outside tube for wing strength . and its strong . the winch housing has 6mm front plate with 16mm plate behind that the winch bolts into , and is also gusseted onto the plate , then in front of the 6mm plate there are 12 plate sections you can see with two recovery points welded which are more than strong enough . the tube is 45od tube with 5mm wall thickness , and the mounts from the bar to the chassis are 10 mm plate then have top and bottom captive bolt and the standard 4 on the side . in the photo i just had the standard bolts holding it on to get final measurement for a clamping plate on the inside of the chassis to reduce any stress on the chassis from winching . i think i can happily say that she wont budge . the only bad point is that if in the case i was to have a bad accident . the bar would most likley bend the chassis . but im not worried . oh and for brooksy , surprisingly the whole thing doesnt weight heaps . you can pick it upp and walk with on your shoulder no worries at all . im nothing special in bar making by any means but i went into arb , and i have seen 14 year old boys lay neater welds than that . i wouldnt touch those things with a ten foot pole
Squiggs351
Re: Front tube bars
Unread post by Squiggs351 » April 16th, 2012, 11:58 pm
Here's one i made for my Hilux, took about 4 hours to get to this point, still need to fit brackets for LED indicators and ground lights and winch mount but that won't take long. I only wanted something basic on it 'cos i'll probly change it later anyway.
LN106 Hilux D/C,EFI 5Litre and 4L60E, 2" spring lift, 2" body lift, 33x12.5 muddies, custom snorkel, custom tube winch bar.
BUILT... NOT BOUGHT...
Return to “Extreme Tech”
