ATF - Which one?
By popular demand!
Taxman
ATF - Which one?
Unread post by Taxman » December 17th, 2009, 9:23 pm
I had the transmission in my 96 LTD serviced by a mechanic I had been using for yonks. We discussed that it had to use Mercon V - he agreed. Four days later about a mild from home I lost drive. Waited for it to cool down and limped home.
Rang the mechanic - no answer, walked around, his place was locked up tight as and he hasn't come back. Nobody knows where he has gone - not even his wife.
It has been suggested that he probably used whatever ATF he had left before he did the bolt. It has been suggested that if I drain the ATF he put in and replace it with the correct stuff it may fix the problem (I hope).
I rang the local Ford Dealer his spare parts dept said they only sell it by the one litre bottle, its 'bloody' expensive and they don't have any in stock, they would have to order it in take a week or two and will cost over $300 (he thinks).
The Questions:-
1. Is it possible that by replacing the ATF with the right fluid is it likely to fix the problem?
2. Does Castrol or any other oil manufacturer make a suitable replacement?
3. Is it a mineral or synthetic oil or does it matter?
Thanks in advance
Peter
1996 Explorer Limited, extra leaf in rear suspension, 50mm Torsion Bar lift,driving & fog lights.
1991 Surf, Bullbar, Towbar, 50mm suspension lift
98fex
Unread post by 98fex » December 23rd, 2009, 7:14 pm
Taxman wrote:I had the transmission in my 96 LTD serviced by a mechanic I had been using for yonks. We discussed that it had to use Mercon V - he agreed. Four days later about a mild from home I lost drive. Waited for it to cool down and limped home.
The Questions:-
Thanks in advance
Peter
Hi peter penrite make a mercon V replacment
Taxman
Unread post by Taxman » December 24th, 2009, 6:05 pm
Thanks Darren I thought you would be able to provide me with an answer
Peter
98fex
Unread post by 98fex » December 24th, 2009, 9:48 pm
Taxman wrote:Thanks Darren I thought you would be able to provide me with an answer
Peter
its about $55 for a 3L bottle
Dreagteet
куплю кабель авббшв
Unread post by Dreagteet » April 4th, 2011, 8:34 am
кабельные заводы снг [url=http://jb4nmb0etzs.livejournal.com] кабель пввнг [/url]
провод силовой 5х16мм провод бсм производители [url=http://kwxr0muhlnh.livejournal.com] список кабельных заводов [/url] кабель силовой с пвх изоляцией [url=http://zasomove.livejournal.com/] провод пвс 3 [/url]
кабель силовой экранированный продаем кабельный лом [url=http://qrrzxvfbmrd.livejournal.com] судовой кабель кнрэтэ 33х1 [/url] кабель силовой на напряжение 660 в [url=http://ipsoi2nmgxo.livejournal.com] кабель силовой с медными [/url]
силовой кабель ввг прайс кабель силовой пв1 31х35+1х25 [url=http://cabel33.ru/] кабель силовой авббшвнг [/url] силовой медный провод [url=http://fifelath.livejournal.com] мальчик потерял руку на задев силовой кабель [/url]
термостойкий провод куплю судовой кабель кмпвэ 14х0.35 [url=http://0ctsdoftb2m.livejournal.com] судовой кабель кмпвэв 3х0.5 [/url] куплю провод пвс шввп [url=http://fanf2l0py3n.livejournal.com] куплю провод ас [/url]
провод неизолированный куплю силовой кабель [url=http://52ncqkapgsv.livejournal.com] продаем кабельный лом [/url]
Taxman
Re: ATF - Which one?
Unread post by Taxman » April 4th, 2011, 8:33 pm
куплю кабель авббшв
кабельные заводы снг кабель пввнг
провод силовой 5х16мм провод бсм производители список кабельных заводов кабель силовой с пвх изоляцией провод пвс 3
кабель силовой экранированный продаем кабельный лом судовой кабель кнрэтэ 33х1 кабель силовой на напряжение 660 в кабель силовой с медными
силовой кабель ввг прайс кабель силовой пв1 31х35+1х25 кабель силовой авббшвнг силовой медный провод мальчик потерял руку на задев силовой кабель
термостойкий провод куплю судовой кабель кмпвэ 14х0.35 судовой кабель кмпвэв 3х0.5 куплю провод пвс шввп куплю провод ас
провод неизолированный куплю силовой кабель продаем кабельный лом
Sorry, although I speak several languages I don't read them. An English translation would be appreciated.
Taxman
98fex
Unread post by 98fex » April 28th, 2011, 4:09 pm
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT" onclick="window.open(this.href);return false; about $ 1100 to your door not to bad
Return to “Explorer”
