spotlight wiring grand vitara
Pre 2005 GV's
bigbluegrand
Unread post by bigbluegrand » July 10th, 2012, 6:58 pm
Anyone now how to wire up spotties on 99 grand vitara? done plenty of other cars no problems but this ones got me stumped there is power to the headlights all the time
ERASER
Re: spotlight wiring grand vitara
Unread post by ERASER » July 11th, 2012, 7:22 pm
Theyre negative switched. The 12volts is always at the light and the negative gets switched at the switch. So basically you wire it the same way just with reversed polarity on the relay. So relay with always have 12volts at it but wont have a neg/earth. You get the neg/earth from the lights so when the lights come on they supply the relay its negative and it turns on. Then you wire the rest the same as any other system.
My Hilux
BAZZOOK
Unread post by BAZZOOK » August 28th, 2012, 10:55 am
c/- auszookers.com
Return to “Grand Vitara / XL7”
