lift kit 2003 GV
Pre 2005 GV's
mas75
lift kit 2003 GV
Unread post by mas75 » July 28th, 2011, 6:56 pm
Hi guys. I just got a 2003 GV and would like any ideas on a good lift kit. Also the best BG Goodrich AT size for it. Thanks
wombat4u
Re: lift kit 2003 GV
Unread post by wombat4u » July 28th, 2011, 7:20 pm
225 / 70 16. I have Maxxis AT 771 that work well.
ODA1
Unread post by ODA1 » July 29th, 2011, 2:39 pm
try - http://outdoorauto4x4.com/b/22764/1/suzuki-vitara.html" onclick="window.open(this.href);return false;
for tyres you can go a 245/70/16 in an at or 225/75/16 in a mud or a 235/70/16
all these tyres will rub slightly you will have to bend a small tab in the front wheel arch to clear them when turning
also you will loose a little power and the sppedo will be out by 8Ks at 100
mas75
Unread post by mas75 » July 29th, 2011, 6:14 pm
Thanks for that guys, and thanks for the heads up on the speedo reading change. I was thinking there would be a change but wasnt sure how much.
Mitch123
Unread post by Mitch123 » July 30th, 2011, 10:44 pm
Lift Kit: Ironman ($700 through Bursons)
Did the rear myself and got Ironman to do the front for $100.
Tyres: Bridgestone Dueler A/Ts. 245/70/16 ($215 each, supply/fit).
Only just fit, scrub the inside front guard when on full lock.
The lift kit and bigger tyres combination gave me a 65mm lift overall.
mas75
Unread post by mas75 » July 31st, 2011, 10:50 pm
Thanks Mitch123. About how long have you had the kit and are you happy with it.
Mitch123
Unread post by Mitch123 » July 31st, 2011, 11:30 pm
Got the lift kit about 2 years ago. Felt a bit stiff at first but quickly settle down and haven't had any problems. Very happy with the extra height has certainly helped when out on the tracks. Would have preferred getting some mud tyres for that extra grip, next time....
ODA1
Unread post by ODA1 » August 1st, 2011, 10:50 am
i have heard good things about the iron man lift for the 98-05 Grand vitara
the lift is only 35mm though but i would love to see pics of the tyres fitted :-)
Mitch123
Unread post by Mitch123 » August 2nd, 2011, 9:13 pm
Couple of pic's of my 245 70 R16s
No room for snow chains :(
fordem
Unread post by fordem » September 28th, 2011, 12:11 pm
mas75 wrote:Thanks for that guys, and thanks for the heads up on the speedo reading change. I was thinking there would be a change but wasnt sure how much.
It's an electronic speedometer - fairly easy to correct - Jaycar has a kit that can do it.
jaimit1995
Unread post by jaimit1995 » September 10th, 2014, 12:34 pm
This is a very old thread, but thought i'd attempt to revive it!
How is the ironman lift going? I'm currently chasing one for my new 02 GV and would love to know how it's held up!
Also, does anyone know the biggest tyres that will fit onto the GV with no lift? do 245/70/16 in normal road tyres fit with no rubbing? (I've been travelling on pretty tough tracks with HT tyres while it's relatively dry and no complaints tbh!)
1st Car - 2007 Holden Astra Wagon.
2nd Car (Current) - 2002 Suzuki Grand Vitara.
WORK IN PROGRESS, Mods to come.
Return to “Grand Vitara / XL7”
