TJ Wrangler - Diesel conversion kits???
wooders
Unread post by wooders » July 8th, 2009, 12:07 am
Forget that. Theres quite a few yanks that have swapped in the Cummins 4bt - which is a nice fit - do a Google for "TJ 4bt".
Although I'd prefer the 5.9L 6BT over the 3.9L 4BT ;)
[b]Cheers
[/b][url=http://www.wooders.com.au]Wooders[/url]
JOEL1977
Re: TJ Wrangler - Diesel conversion kits???
Unread post by JOEL1977 » September 15th, 2012, 6:02 am
Hi I'm about to convert my 98 tj from 4.0 5 speed to a turbo diesel auto !! Im looking to buy a Toyota surf 3.0 (station wagon verson of a hilux) auto to swap in as there's loads of them been imported to the uk and there not as dear as a hilux !!
My advice to you is put what ever engine in your jeep that suits you & your needs
I'm swapping over to diesel as I use my jeep off road with loads of winching and water crossings so it gets a hard life and is always running hot & hate water the Toyota engine has plenty of power and much Cheeper to run
Good luck with your swap
Regards Joel
Toyota Landcruiser 100 series & Jeep Wrangler TJ
gen1__pajero
Unread post by gen1__pajero » September 15th, 2012, 9:55 am
Thats great JOEL1977 please keep us informed on how u go. would love to put a diesel in my 06 tj.
cheers jamie
JOEL1977
Unread post by JOEL1977 » September 16th, 2012, 4:33 am
I will keep you updated it should be an easy swap and one of the real plus,s I'm looking forward to getting rid of the poxy key fob imbolizer that are on all uk jeeps I don't know if you guys have them on your motors ? There wired in to the brain ecu and a night mere !! Soon to be gone for good when the tj is running diesel !!
gen1__pajero
Unread post by gen1__pajero » September 17th, 2012, 1:01 pm
I dont thibk we have them here. well at least mine does not. diesel is so much better.
JOEL1977
Unread post by JOEL1977 » September 23rd, 2012, 12:48 pm
Iv seen a mitsubishi pajero engine & box in a TJ it's one of the few motors to have transfer box on left and a center tale same as Jeep TJ as most other makes are all on the right with off set rear diff just an idear as you have Pajero,s in AUS that's if you was going for engine & box swap as I am !!
Return to “TJ Wrangler”
