Problems Lifting Jeep
GQcress
Unread post by GQcress » June 17th, 2012, 9:28 pm
Hi ive just recently lifted my girlfriends TJ with a 2" lift and put 33"s on it and have found that where the old spring use to seat itself now is rubbing on the tyre, im trying to find out if any one else has run into this problem? i was thinking of putting 1 inch wheel spacers on it and was wondering weather its enough to also allow for the tyre to flex and not rub on this agan... ??
TroopiePete
Re: Problems Lifting Jeep
Unread post by TroopiePete » June 17th, 2012, 9:36 pm
If you don't get a good reply from this forum try OZ Jeep - wealth of experience to jeep related things on there.
Peter Richens - VK4FSD
HF Radio club - 4115
River City 4WD Club - President 2010 - 2014 http://www.rivercity4wdclub.net
BLU-125
Unread post by BLU-125 » June 18th, 2012, 9:15 pm
Front or rear springs?
2004 GRAND CHEROKEE OVERLAND.
WHAT SIDE WAS YOURS ON IN WW2? :)
GQcress
Unread post by GQcress » June 19th, 2012, 4:30 pm
rear springs
BLU-125
Unread post by BLU-125 » June 19th, 2012, 8:25 pm
What size & offset rims are you using? Are they 33/12.50R15s or some other size?
GQcress
Unread post by GQcress » June 22nd, 2012, 8:54 pm
yeah there 33/12.50R15s bit of a wide tyre but there has to be ways to make them fit...
BLU-125
Unread post by BLU-125 » June 23rd, 2012, 5:45 pm
The rim size and offset that tyre stores sell to suit that size tyre normally don't allow a problem. If they have been fitted to the standard 15x7 rims, which is far too narrow for the tyre anyway, then this will be the problem.
What size & offset are the rims?
BTW, wheel spacers are very illegal in OZ.......... ;)
Return to “TJ Wrangler”
