riagan
Unread post by riagan » June 23rd, 2015, 6:52 pm
couldn't stand waiting to take my truck to holden, had to put the new rims and tyres on!!!
265/75R16
Tuff t06 +10 offset
no scrubbing and they finish flush with the guards
photo isnt the best as i smashed the camera lense! :D
Pirate78
Unread post by Pirate78 » July 6th, 2015, 8:40 pm
Hi just fitted some 265/65/17 a/t falken wildpeak on dynamic steel rims and seem to fit fine with no rubbing as there is plenty of room in the wheel well. A Bit more of an aggressive look for the collie rather than running the standard rims.
SomeCant
Unread post by SomeCant » July 15th, 2015, 5:42 pm
had these put on a little while ago
265/75/R16
they just scrubbed the front mudflap at full lock, there was like a 1cm lip on the mudflap I cut off and they don't hit at all now.
being 75's they put my speedo out by 3kmh so 97 is really 100 until I can get to the dealer and have them correct it lol
they are pretty quiet on the road too :)
ColoradoinOz
Unread post by ColoradoinOz » July 15th, 2015, 9:59 pm
Any pics Pirate78? I like the look of the Wildpeaks as an all terrain tyre, Was thinking about getting a set on 20" rims ( 285 / 50 / 20 ) to do mostly on road stuff & keep my 16" Goodyear Wranglers for off road
Azza88
Unread post by Azza88 » October 28th, 2015, 10:45 am
I've managed to score a very cheap set of near new 285/70/17 muddies I intend to use as a second set for off road trips only. Question is what offset steel rims would fit? The tyres work out to be 32.7 inch. I've already got a 50mm lift front and rear. I see people are running 33's with minor mods to mudflaps etc?
Thanks in advance guys
2013 Colorado LTZ Auto Spacecab- ARB deluxe bar, safari snorkel, 32" LED light bar, GME UHF, 50mm Bilstein lift, 17" Raptor rims with 275/65 r17 maxxis 980 AT's, ARB compressor, winch.
RADO12
WILL 20x9 rims and 285/50/20 tyres fit RG with 2in lift
Unread post by RADO12 » December 5th, 2015, 12:45 pm
Hi All
Just wondering if WILL 20x9 rims and 285/50/20 tyres fit RG with 2in lift and I think the rims are +12 offset.
RADO12
Unread post by RADO12 » December 5th, 2015, 1:28 pm
Hi All
robbie_wog
15" rims on an RC Colorado?
Unread post by robbie_wog » December 26th, 2015, 5:54 pm
Who's managed to fit 15" rims on their RC Colly?
I want to fit a set with an offset around +15 so I can fit 32x11.5s with 2" lift
Anyone got some experience?
Help only, no 16" bandits please ;)
luxy 99
Unread post by luxy 99 » December 30th, 2015, 1:44 pm
Ive got 15 on my colly un shore of off set as they came off my b rothers triton but I had to use a 3mm spacer on front back ones fit fine ive also had 15 x8 0offset they clear with out spacers
claycolly
csa raptors on bfg ko2
Unread post by claycolly » January 13th, 2016, 5:18 pm
I'm looking to upgrade my 2014 rg colorado wheels to 17x8 csa raptors P25 on 265/70/17 bfg ko2s on standard height.
Wondering if anyone has a similar setup. Will that size tyre fit without scrubbing?
Also does anyone have a set of csa raptors on their Rg? How have they been?
riagan
Unread post by riagan » January 13th, 2016, 8:06 pm
Won't fit claycolly. I have a 2 inch lift with the same size tyres and more offset and they still rub occasionally.
claycolly
Unread post by claycolly » January 14th, 2016, 5:46 pm
Ok thanks riagan. Do you think if I went with 16" id be fine? Had a think today and might go with 265/70/16 instead of the 17". Cheaper and also won't have to worry about gear ratio with mine being an LX.
ColoradoinOz
Unread post by ColoradoinOz » February 6th, 2016, 12:21 am
A 265/70/17 tyre will fit just fine with stock suspension & +25 offset rims claycolly
That size is exactly the same as a 265/75/16 which is well known to be the largest you can actually fit on a totally stock RG>
(16" shown in orange & 17" size shown in the green section)
http://www.willtheyfit.com/index.php?wi ... 25#content
This is my RG when it was literally one day old, totally stock with no lift at all shown with 265/75/16 Goodyear Wrangler "kevlar" tyres on 16x8 +20 offset rims
The front tyres just touched the mudflaps near full lock but these are a large chunky deep tread tyre for the sizing
skronkman
Unread post by skronkman » May 11th, 2017, 11:42 pm
Just thought I'd add to this quickly. I have an RC dual cab, 2" lifted springs in the rear and the front torsion bars wound up to suit. I have 16x7 sunnies with +22 offset. I tried running 265/75 but they scrubbed on lock. I cut out the insides of the front guards to make room, it helped but still scrubbed. I tried a few more things but gave up and ended up going for 265/70 BFG AT. And am happier with the performance and no scrubbing. I checked my speedo today and when it said exactly 100km/h my gps said I was doing 98km/h.
csumich
Unread post by csumich » July 8th, 2018, 8:21 am
Hi people new member, I’ve got 265 70 16 on my rg Colorado wanting to know if 285 70r 16s will fit? I do have a 2 inch lift
Return to “Colorado”
