Nemesis
Unread post by Nemesis » September 12th, 2014, 4:35 pm
Originally started as a research topic years ago in the older utes sections, the tyre topics are so popular it's time to start an new info archive in each sub section, not just for the older ute people!
mattyc91
Tyre size
Unread post by mattyc91 » January 24th, 2015, 9:25 pm
on my RC I currently have 245/75R16 (standard are 245/70r16) , I'm due for a new set and wondering if I should keep the same size I have now or go 255/70r16 which are slightly smaller in height but are then slightly wider. I can't really see much difference to be honest. I only go off road every couple of months and don't want to go any bigger so I can keep it legal and keep the fuel economy down, I have 2" suspension lift.
PR15KY
Unread post by PR15KY » February 6th, 2015, 7:09 pm
just got a set off 33"s fitted today and ran into the issue of tyre just scrubbing on full lock on body, toying with ideas to fix this atm but boy does it look sexy with all that rubber underneath
2015 RG collie built for some tough love in the outback
DI.57.BD
Unread post by DI.57.BD » February 7th, 2015, 8:07 am
I have fitted 33's to standard LT rims and have next to no scrubbing, also running a 2 " lift.
DarKasH69
Unread post by DarKasH69 » February 7th, 2015, 3:47 pm
You say YA got 33s. Are they still 245 wide on the standard rims ?
Cheers.
WHEN INJUSTICE BECOMES LAW,
RESISTANCE BECOMES DUTY....
MudTrucK Up !!!
PR15KY
Unread post by PR15KY » February 7th, 2015, 6:01 pm
the ones i had fitted that r rubbing slightly are 285/75R16's
DI.57.BD
Unread post by DI.57.BD » February 7th, 2015, 6:54 pm
DarKasK69- 285 75 16's on the standard rims. originals are 245's.
Mazda13b
Unread post by Mazda13b » February 8th, 2015, 6:27 am
Are The stock rims 16x7? I'm looking at Getting 33s on my 16x7 black steelies but hearing conflicting info
DI.57.BD
Unread post by DI.57.BD » February 8th, 2015, 11:18 am
The standard rims are 16x6.5, i tried 16x8 +20 rims and they hit the body mounts, so i tried the standards and the tyre just touches the sway bar at full lock, depending on the offset of your 16x7 they might fit, try this offset calculator.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Its what i used to work it out.
DarKasH69
Unread post by DarKasH69 » February 8th, 2015, 12:20 pm
That's Kool. Didn't know 6.5" wide fitted 285s.
Very Kool.
What lift have YA got ?
I'm guessing 285s will be too tall with just a 50mm lift !?!
MudTrucK Up !!!
DarKasH69
Unread post by DarKasH69 » February 8th, 2015, 12:25 pm
DI.57.BD wrote:I have fitted 33's to standard LT rims and have next to no scrubbing, also running a 2 " lift.
Sorry. You said here.
MudTrucK Up !!!
DI.57.BD
Unread post by DI.57.BD » February 8th, 2015, 5:33 pm
There is afew people running 33's with 50mm lift including myself, havent had any dramas.
DarKasH69
Unread post by DarKasH69 » February 8th, 2015, 6:26 pm
Ok. Have YA got a pic of them on ya 6.5" rims.
Appreciate it if YA could.
MudTrucK Up !!!
DI.57.BD
Unread post by DI.57.BD » February 10th, 2015, 4:13 pm
Here is a pic on the standard LT rims, BF Goodrich At's in 285 75 16.
Here is a pic of them on the front.
DarKasH69
Unread post by DarKasH69 » February 10th, 2015, 5:14 pm
Ok. Kool.
Firstly I like them rims better than the standard steel rims on my LS.
Are you sure they are 6.5".
They don't seem to hang out the side of the rim much. Very neat lookin setup.
Was going to go down size to 265/75/16.... But the look of the 285/75/16 looks chunky.
Dig it.
cheers mate. Appreciated.
MudTrucK Up !!!
Return to “Colorado”
