colorado dual batteries
runner
Unread post by runner » November 27th, 2010, 1:31 pm
any one fited dual batteries to ther colorado in the engine bay or just in the tub trying to figure out where is best
runner
Re: colorado dual batteries
Unread post by runner » December 4th, 2010, 5:16 pm
so no one has come up with a solution I'm still trying to figure it out
honestcozzie
Unread post by honestcozzie » December 4th, 2010, 5:56 pm
Had to stick mine in the tub no room anywhere else, was hoping to put it in the engine bay no room in there so in the back it went.
runner
Unread post by runner » December 4th, 2010, 7:41 pm
hi
i just crawled under the car and i recon i could fit a optima d34/78 in the area taken up buy the huge factory muffler is and fitting a smaller muffler one cross member forward
i am amazed by the lack of room under the bonnet found a spot for the red arc isolator captive m6 nut next to power steer res
cant even find a home for my compressor wanted it under the bonnet to allow future diff locks
Spacecab
Unread post by Spacecab » December 5th, 2010, 10:11 am
runner wrote:hi
As far as the muffler goes don't bother with a smaller one, the only noise you will hear with a straight through pipe is when towing a van uphill in 4th and that is if you listen hard.
Steve
runner
Unread post by runner » December 5th, 2010, 11:36 am
cheers for the advice i wouldn't mind hearing a bit more of a exhaust note any way
CPC
Unread post by CPC » December 6th, 2010, 6:43 pm
runner wrote:hi
That's where I'll be putting mine. I'm going to have a cradle made up for it. I'll be removing that rear section of exhaust and having a straight through piece made up and directed over the other side of the vehicle. I hadn't decided where I'd be putting my compressor yet.
Chris.
J5
Unread post by J5 » December 10th, 2010, 9:45 pm
CPC wrote:
runner wrote:hi
Chris.
pirahna make a tray for an 8 inch battery under the bonnet
i had my air compressor fitted under the passenger seat which works well
S.W
Unread post by S.W » December 11th, 2010, 3:15 pm
Has anyone fitted one of these, or have photos of another underbonnet dual battery setup for the Colorado?
I thought all the trays available were for the Rodeos which didn't have ABS fitted and now that ABS is standard the left hand side back near the firewall is too cluttered for the tray to fit. I hope I'm wrong!!
CPC
Unread post by CPC » December 20th, 2010, 3:52 pm
Bumping this. I'd like to see if the tray will fit too.
Chris.
PJG
Unread post by PJG » December 27th, 2010, 3:16 pm
It is for non-ABS Rodeo's. I downloaded the install manual and it goes where the ABS modulator is.
We put our second in the tray when we use, and disconnect it when not in use. Will use a permanent solution at some stage, probably not until we've got a canvas canopy for the tray. Was thinking about an under tray box.
As for the compressor, you should fit one under the front passenger seat, I had one there in my 2000 Rodeo which had a rear locker. Under the bonnet is not a nice place for accessories anyway, gets hot and dirty ;)
leckie
Unread post by leckie » December 27th, 2010, 4:50 pm
Are you guys that have dual batteries running them as start batteries or just as an auxillary power 2nd battery?
J5
Unread post by J5 » December 29th, 2010, 4:39 pm
that would be 2nd power
really looking into this now as want to get a fridge soon
IMPOSE
Unread post by IMPOSE » January 2nd, 2011, 11:12 am
Don't know if this of interest to anyone, but found this pic whilst checking out Pre-Runner trucks. Its under a 2008 Chev 1500.
Kransky
Unread post by Kransky » February 4th, 2011, 10:04 pm
Umm, that battery is just waiting to be smashed :eek:
Col.
Return to “Colorado”
