Best knot for trying winch rope on??
Mino
Unread post by Mino » October 5th, 2011, 5:21 pm
Was just wondering if you guys/gals have any good ideas or suggestions on what knot to use to try on my winch rope.
Was out in the mud and it pulled out of the crimp. Thinking of tying it back on instead of recrimping it..
Any ideas would be great.
thanks
Chris
Mino
Unread post by Mino » October 5th, 2011, 5:34 pm
thanks
Chris
Aaron Schubert
Re: Best knot for trying winch rope on??
Unread post by Aaron Schubert » October 5th, 2011, 8:02 pm
If you are using the winch correctly, it shouldn't matter. The strength in the knot should do nothing anyway - the winch works on having enough friction from several wraps of rope around the spool to not slip and unwind.
Aaron
My 80 Series Landcruiser
cac
Unread post by cac » October 5th, 2011, 8:09 pm
my suggestion would be to recrimp it, then not use the last layer on the drum when you are winching out of a bog.....the friction between the rope and the drum will limit the amount of slip, and therefore reduce the load on the crimp....
LN106 Hilux Project
Unread post by Peter Aawen » October 5th, 2011, 8:33 pm
Which end did the crimp pull out of?? If it was the drum end then you shouldn't have been winching with that much rope out!! You should make sure that you always leave at least 5 full turns of rope (or cable) on the drum when you are winching, it will take at least that much to maintain the rating of the pull, as you found out. So like cac says, recrimp it, refit it, and never use the last layer of rope on the drum!!
If it was the hook end, you can use a bowline to secure the hook (but if you ever want to take it off you'll probly hafta cut it!) or better yet, splice the rope into an eye around the loop on the end of the hook. The latest Custom Guide mag shows you how to loop & splice rope to do that, and most of the rope supplier websites (like Dynamica etc) have a diagram to show how to do it too.
HDJ78R
Unread post by HDJ78R » October 5th, 2011, 8:38 pm
What's been said by cac and pete.
Mino
Unread post by Mino » October 6th, 2011, 9:51 am
Ok thanks guys.
Any ideas where i can get a decent crimp from??
HDJ78R
Unread post by HDJ78R » October 6th, 2011, 10:45 am
I reckon a shop that sells winches and winch accessories mate. If they don't have it, they should be able to order one in.
Aaron Schubert
Unread post by Aaron Schubert » October 6th, 2011, 3:53 pm
I'm sure I replied to this thread. Where'd it go? :o
Aaron
Aaron Schubert
Unread post by Aaron Schubert » October 6th, 2011, 3:54 pm
Never mind - you made 2 threads up. The other one is at viewtopic.php?f=12&t=120417" onclick="window.open(this.href);return false;
Aaron
GBC
Unread post by GBC » October 6th, 2011, 4:13 pm
figure of 8 is the accepted 'stopper' knot mate.
Unread post by Peter Aawen » October 6th, 2011, 4:19 pm
They're merged now - please remember people, 1 subject, 1 Section, 1 thread!
Duplicating threads makes it LESS likely you'll ever get the full answer in one place; makes searching really difficult; and tends to annoy those people who've already answered ;)
Pm sent Mino, check it out via the New Messages link up the top left under the 4WD Action Logo.
cac
Unread post by cac » October 7th, 2011, 12:50 pm
I reckon there'd be a few knots that would do a sufficient job of securing the rope, but using a series of round turns and a crimp means you have a uniform diameter for each layer of rope on the drum....
LN106 Hilux Project
GBC
Unread post by GBC » October 7th, 2011, 3:59 pm
I'm assuming the drum has a hole in the side and the crimp was outside the drum?
Tim B
Unread post by Tim B » October 7th, 2011, 8:36 pm
Hi guys and gals,
I have rope on my winch and at the drum end i have braided the rope onto the drum..
You should never let your rope on the drum when winch get lower than 5 rapes on the drum whether it be rope or cable.
But having the rope braided onto the drum should it get below 5 rapes on the drum the braid will always hold you if done correctly unlike the crimbed on clips. As soon as the load becomes on the clip,it will let go ever time.
Cheers Tim...
