07 Ranger thrown P0663 code & won't rev - any ideas?
Jerdes
Unread post by Jerdes » July 8th, 2018, 7:29 pm
Hey guys,
Noticed the ute (07 PJ Ranger) has recently thrown a code.
It's coming up as P0663 and when you search on the net, it says what it is but it's pretty vague and doesn't really show how to fix it.
The ute drives fine most of the time, however I have noticed sometimes it won't rev past 2500 RPMS.
Also noticed that it goes on and off randomly.
Anyone else come across the error and know the best way of fixing it?
Cheers!
fleetwood
Re: 07 Ranger thrown P0663 code & won't rev - any ideas?
Unread post by fleetwood » July 19th, 2018, 8:51 am
Sounds like a problem with the Intake shutter valve & the fault code confirms it... Not revving past 2500 is a sign that the half shut mechanism is at play when it shouldn't be
Disconnect & block the 2 vacuum hoses that go to the ISV & see if it makes a difference... If it fixes the problem, it could be either the solenoid, a jammed butterfly, or the hoses are reveresed
