What's covered in the 200K Service Schedule?
Ranger 4x4 Life
Unread post by Ranger 4x4 Life » May 28th, 2018, 10:05 pm
Hey, does any know what's covered in the 200k service? The book only gives details up to 160k service :crazy: Was intending to get Ford to do it, but their service now cost $725. Up about $100 from when I checked, when I did my 190k service about 5 months ago. :eek:
Re: What's covered in the 200K Service Schedule?
Unread post by Peter Aawen » June 1st, 2018, 1:11 am
Check out the service book &/or glove box manual carefully. They usually have a 'Service Schedule' page or entry that spells out what needs to be done at what intervals, not just what needs doing at any given milage (or kilometerage - if that's even a proper word?!) So you can see that at every 5k you need to do engine oil & filters; 10k add air filter & check the brakes; 40k do the hubs & uni's, 60k dump & replace the diff & gearbox oil; & so on in the same vein - it generally doesn't start getting really repetitive until about 160k, so that might be why your book only goes that far - you then go back to the beginning & repeat! :p
Cyclone Ranger
Unread post by Cyclone Ranger » August 5th, 2018, 6:01 am
Hi Ranger 4x4 life,
Yes your manual only goes to 160K so then you start at the beginning again!!
200k - 160k equals 40k so you do the 40k service @ 200k
My PK has done 254k so my next service is 260k so I will be doing the 100k service!!
Do you understand what I'm saying??
Cheers Cyclone Ranger :thumb:
