PJ Ranger Hi-rider Front Wheels Bearings - what Torque is Needed?
jcsaws
Unread post by jcsaws » April 25th, 2018, 11:46 am
Hi
Does any one have the correct torque for a PJ Ranger front wheel bearing on a 3lt Hi-ride 2x4? The workshop manual info on Dropbox only shows 2x4 2.5lt standard height which uses the tapered bearing on a std stub axle like a trailer, 11nm. The Repco workshop web help page that a mate looked up had 200 to 314nm, but that's for the drive shaft. So, expecting that the 34mm nut would be bloody tight, I got a 2ft pipe on my Sidchrome breaker bar - but it wasn't 250 nm. Any help please? I need the info today if possible. Using CBC bearing kit - FM123KIT.
Will post pic soon.
JC
Re: PJ Ranger Hi-rider Front Wheels Bearings - what Torque is Needed?
Unread post by Peter Aawen » April 25th, 2018, 7:08 pm
SKF Bearings publish a PDF (457377) that pretty much shows most of their wheel bearings needing 220-305nM or something close.... dunno if that's early enough to be of any help to you?! But it's a good start, altho it is definitely still worth checking! ;)
jcsaws
Unread post by jcsaws » April 26th, 2018, 8:05 pm
Thanks Peter
I did it back up to the notch on the nut. It went past the max on my torque wrench. so most likely up over 200nm.
If i open this forum on phone i cant load pics, but will keep trying.
For anyone with bearing noise, it was my thought it was the diff again. It only was evident after taking the wheel and brake rotor off that it appeared a bit noisy. It was very dry.
JC
