How to change Ranger Air Filter (and oil change)
Hi all.
1) Apologies if its been discussed numerous times, new to forum and the Ranger, but could someone go through the steps of how to change the air filter?
I took the three clips off but I am wondering what to remove next so I can lift the cover off.
2) Also, is there a sticky for the recommended air filter as in the regular ryco or something else?
3) I just changed the oil filter. Used the standard ryco but realised its slightly smaller and now wish I got the motorcraft. Will do next time. I took off the bottom protection plate off to get to the sump plug. It still made a hell of a mess as it dripped on the forward plate in front of it (if that makes sense). Do I take this off too? What's the best way to do this?
Ranger 4x2 PK 2009
Unread postby Cloudy Burster » January 8th, 2013, 8:02 pm
Re: How to change Ranger Air Filter (and oil change)
G'day mate, with air filter I just lift top up till I'm able to remove filter but if its to tight ya may need to undo any hoses restricting movement. With oil change I also take off both bash plates you still get oil everywhere but makes it easier. I use motorcraft oil filter cause it was handy tycoon should be fine.
Cheers brenton
Unread postby barrafly » January 8th, 2013, 8:19 pm
Hey Barra, yeah there is a large pipe that goes over the top of the air filter, surely this doesn't have to be removed??
Ranger 4x2 PK 2009
Unread postby Cloudy Burster » January 9th, 2013, 10:05 am
Not 100% sure ill check when I get home.
Unread postby barrafly » January 9th, 2013, 12:42 pm
Cloudy Burster,
The large pipe does not need to be removed. Just lift the lid of the air box and replace your filter.
2008 PJ Dual Cab 5sp Man 4x4 XLT Ranger
Mods: 2" Snorkel Lift, Phillips Sports Headlight Globes, Tinted Windows, Chromed Wheel Nuts, & an Aftermarket AM/FM Aerial
Unread postby XLT Ranger » January 9th, 2013, 5:48 pm
Ive had the same problem trying to open the air filter box to get to the filter. It only allows a 20degree angle open and as its hitting the hose it locks itself, I am going to try cutting the tie strap holding the hoses together and see if this gives enough room but i still believe there is another way to do this. Anyone care to share a step by step process?
Thanks,
Unread postby C32 » January 11th, 2013, 11:22 pm
Return to PJ/PK Ranger / Old BT50
Who is online
  • Follow US
4wd Action Club
Member
Login
Join the Club
