BT-50 MAF sensor learning procedure - DLC-1 ??
ZookNC
Unread post by ZookNC » March 9th, 2011, 10:46 am
Hi everyone,
Like a lot of us I followed the instructions in another thread on this forum to clean the MAF and MAP sensors on my BT-50. The Mazda training manual that I got off the net indicates that in order to launch the MAF sensor learning procedure, you must earth the TEN (Test ENgine) terminal on DLC-1 (Data Link Connector) five times in as less than 5 seconds.
Problem is I know where DLC-2 is situated, thats the one you connect the scan gauge to but I have no idea where DLC-1 is or what it looks like. the manual seems to place it in the passenger side footwell, below the A pillar or somewhere close under the bonnet but I'm not sure.
Does anyone have an idea ? A pic would be great if possible.
Thanks in advance,
Arnaud.
GeoffMBT50
Re: BT-50 MAF sensor learning procedure - DLC-1 ??
Unread post by GeoffMBT50 » March 9th, 2011, 2:22 pm
Hi Arnaud,
I have attached a wiring diagram out of the service manual that hopefully helps.
Cheers, Geoff
ZookNC
Unread post by ZookNC » March 9th, 2011, 5:55 pm
Geoff, thanks a million. I found a plug around the same area as what is labeled as D-02 with nothing to plug into so I reckon that must be it. I'll give it a go and let everyone know if this is the easy way to launch the learn procedure for the MAF sensor.
Cheers and thanks again,
Arnaud.
ranger2452
Unread post by ranger2452 » March 16th, 2011, 5:54 pm
whats the go??
W.A .......whingers anonymous
ZookNC
Unread post by ZookNC » March 17th, 2011, 7:34 am
Well, actually, I haven't tried it yet. The diagram shows what looks like 3
relays on a bracket bolted to the side of the engine bay, my car's only got two relays and a small plug with two wires just sitting there connected to nothing. There is still room on the bracket for something (the data connector I suppose) but there is no sign of it and it doesn't look like there was ever anything there at all. Don't want to take the risk of shorting anything out until I'm sure of what these two wires do.
Will try and see the dealer mechanic Saturday morning and let you know.
ranger2452
Unread post by ranger2452 » March 17th, 2011, 2:15 pm
cheers mate :thumb:
diemonty
Unread post by diemonty » December 4th, 2016, 5:29 pm
Maf sensor re learning 2009 4x4 bt50 3.0l Auto
I cleaned the sensors and my fuel economy went from 10l/100km to 12/100km hence the hunt to find the Maf re learn procedure.
Before I start
“ Extreme “ caution should be exercised with the following procedure because the engine revs up by itself up to 2500rpm .
1/ Warm engine up to running temp “above 82”
2/With engine running diagnostic port pinout “TEN” short to ground 5 times within 5 secs.
3/ if 2/ is done correctly glow plug light will be on then within 30secs the engine will rev up in 3 stages from idle up to 2500rpm.
It will repeat once more through the revs then the glowplug light will flash for about 5 secs then goes out.
4/Turn ignition off wait then restart “done”
5/ use this at your own peril It worked for me and I could not find anything on the net so decided to future proof myself next time I look.
Have not driven too far other than around the block.... test will be next fill of the tank.
cheers Diemonty
ps the other red mark on the dlc is for the testing pin of the shift motor on the transfer case...yet another project.
diemonty
Unread post by diemonty » December 11th, 2016, 6:48 am
Update....
After a full tank of combined highway and in the burbs my economy has returned to 10.3L/100km happy as
well it's as good as it gets, car weighs 2300 kgs automatic with 275 65 r17 tyres. ecuwest tune def helps also.
I did the learn procedure when it was really humid and wonder if the results can be fudged by changing the air intake temps etc.
arief
Unread post by arief » January 21st, 2017, 8:19 pm
hi Diemonty,
How do you short the port pin out?
diemonty
Unread post by diemonty » January 25th, 2017, 4:52 am
Hi Arief
use a piece of insulated wire with ends stripped and firstly find the pin position and stick it in the socket carefully avoid other terminals in the socket.
Then use the other end to "short" to the chassis or a bolt head like on the wiper motor to complete a grounding to the negative side of the 12v system.
don't worry there is no sparks or any indication that anything is really happening until you look at the dash to see the glow plug light.
Diemonty
power ranger
Unread post by power ranger » July 3rd, 2018, 7:53 pm
Hi all,
Looking to revisit this thread and attempt the reset myself. Unfortunately the pics and attachments are lost in cyberspace. Does anyone have any photos they can post with the location of where to earth the TEN terminal on DLC-1?
cbd
Unread post by cbd » July 3rd, 2018, 9:28 pm
Hopefully these are the missing images
cbd
Unread post by cbd » July 3rd, 2018, 9:43 pm
And again
cbd
Unread post by cbd » July 3rd, 2018, 9:44 pm
Last one
power ranger
Unread post by power ranger » July 4th, 2018, 6:18 am
Thanks a bunch!
