What is the wheel off set on a B2500 4x4?
Mazda Musings
Re: wheel off set
Unread post by mydmax » February 12th, 2014, 8:09 pm
Seeing you have the vehicle, measure how far from the centre of the rim width IS the inner face of the wheel centre.
Easy as. Spare wheel, + 2 minutes = offset. Use steel rule to find rim centre point and then slide across inner face to rim. The distance is what you need.
Return to “General Mazda”
