I'm getting Great support for my Foton Tunland!
If you've got model specific Tech questions &/or answers but you're not covered elsewhere, put them in here!
Dmaxqld
Re: I'm getting Great support for my Foton Tunland!
Unread post by Dmaxqld » March 30th, 2018, 9:28 am
DPFs should regenerate every 300-500kms. Suggest you haven’t noticed or don’t have a DPF.
Scantek
Unread post by Scantek » March 30th, 2018, 12:43 pm
Hi
Being a Euro5 compliant build it should have one. I would think.
I had a look under neath and couldn't see one anywhere with all the under body guards.
Then I noticed that there was a Foton DPF for sale on Ebay.
Apparently it is right up near the turbo and it isn't very big. I couldn't see any injector ports on it so I assumed it was part of the exhaust manifold.
If its that close to the turbo maybe it re-gens when under heavy load when the turbo is working hard and the EGT's are up in the high range....
But no I haven't noticed any performance drop or the DPF Re'Gen light come on at all hence why I asked.
Has anyone else noticed a re-gen happening?
Russ
mack1508
Unread post by mack1508 » April 1st, 2018, 1:54 pm
Hi Russ. Yes mine does the same thing. The DPF you are referring to is that the Diesel Particulate Filter and if so where is it as I have changed my muffler to a high flow one.Regards Phil
Scantek
Unread post by Scantek » April 1st, 2018, 7:50 pm
Hi Phil
I cant actually see it on mine but looking at a picture of an engine on Ebay out of a Tunland, the exhaust does a 90 degree straight after the turbo with a cast iron elbow and the DPF hangs off the end of that with a HD band clamp.
So it would be in the hottest part of the exhaust gas. I cant see any injector on it though.
Link below
https://www.ebay.com.au/itm/FOTON-TUNLA ... SwnlFaa8GP
Russ
cmar
Unread post by cmar » April 21st, 2018, 9:53 am
If you can't see pipes and sensors attached that's possibly a close coupled catalytic converter, not a DPF. You don't necessarily need a DPF to comply with Euro 4/5 if the engine is well engineered. My Santa Fe 2.2 R series diesel doesn't have one., yet the mirror image Kia Sorento twin does?
Haven't owned a 2WD since 1982.
Scantek
Unread post by Scantek » April 24th, 2018, 8:57 pm
Hi cmar
Yes that did cross my mind about it being a Cat but it was listed on Ebay as a DPF .
I couldn't see any sensors or injector lines either thats why I asked the question.
I did think you needed a DPF for Euro 4/5 complience though and the dash does have a DPF Re-gen light hence my confusion.
Sorry for taking so long getting back but had an un-planned stay in hospital for a week & a bit after Easter
Russ
Scantek
Unread post by Scantek » July 10th, 2018, 11:28 pm
Hi everyone
Update:
Well had my Ute looked at a few weeks ago and spoke with the new service manager. The flat spot that is apparent is there and part of it. The only solution to this is an ECU re-map. He gave me the name of a company that does re-map in a way that saves the original map as a reset and dynotunes to your requirements. Not sure if I'm going to go that way or not.
The flat spot is more noticeable in the Tunland as they have a higher 1st gear than other items. If you received it higher on take off it's not noticeable.
As for the slipping clutch issue I had, that looks like it's all fixed. From what I've been told it's caused by a faulty spring in the clutch vaccum booster that weakens when it gets hot so deleting this part of the clutch system is the go.
Other than that, all else is going well😁
mack1508
Unread post by mack1508 » July 11th, 2018, 7:51 pm
Hi, Phil here. Do not bother to have it re mapped as it does not work on the cummins. Spoke with Foton mechanic here in Victoria and he told me all the issues with the throttle. He told me off the record to get a blanking plate and blank the EGR off at the exhaust side. The pipe that goes from the top of the exhaust manifold to the inlet is the one you blank off. Look on the internet for the blank plate for the Tunland. I did mine and what a magnificent difference . Trust me it works . No check engine light or any thing. Absolutely happy with it. Regards, Phil.
Return to “Other makes”
