dmax engine same as colorado?
100_cruiser
Unread post by 100_cruiser » December 21st, 2009, 2:00 pm
is the dmax engine the same as in the colorado? or is it similar?
By the way has anyone had any dramas with a dmax? initially wanted a bt50 but seems to be too many problems with clutch/gearbox especially.
[size=100]2010 Colorado diesel dual cab[/size]
hiluxxcab
Unread post by hiluxxcab » December 21st, 2009, 2:29 pm
all the same running gear
cheers craig
Unread post by Peter Aawen » December 21st, 2009, 2:37 pm
I gather from talking to the DMax guys that 'their' version of the engine is more powerful than the virtually identical Colarado, which has a slightly de-tuned version of the same engine. I took both for a drive over the same terrain, and while the difference wasn't all that obvious, if pressed I'd hafta say that I did feel the DMax was a little bit more 'driveable' without having any real evidence to support it - just one of those 'seat of the pant's' things, I guess. Check out the specs for both, there can't be all that much in it!
STEELJOCKEY
Unread post by STEELJOCKEY » December 21st, 2009, 4:57 pm
Both are identical, though from what I've been told, the d-max ECU is tuned slightly differently to spread the torque better, and the cylinder liners are supposed to be low friction melt in liners for better economy. Not sure if that's all true or not, but there is not much in it anyway. American styled panels for the colorado, or old 07/08 rodeo panels for the d-max. 6 of one, half dozen of the other
100_cruiser
Unread post by 100_cruiser » December 21st, 2009, 8:52 pm
rito thanks for the replys there fellas. Looks like i will just get whatever is cheaper. They are doing good deals on the dual cabs ( $35990 i think ) but not on any other models? a space cab would be nice but they want 40k for one. guess i will keep looking.
anyone with problems/reliability issues please post
PJG
Unread post by PJG » December 31st, 2009, 10:43 am
Same engine, but apparently Holden change the ECU so it will connect to their existing diagnostics computers in the dealers. They both quote the same power/torque figures.
oziute
Unread post by oziute » December 31st, 2009, 1:21 pm
I have just ordered one, I'll be picking it up in feb. I did stacks of research on the utes that I liked the look of. The D-Max and the colarado have the 4jj1 engine and on paper the D-max comes out slightly in front.
2010 D-Max. Ironman Bullbar, Ironman Step Towbar, Rhino Racks, Ironman 12000lb winch, Lightforce 240's.
94 Rodeo, 3.1 intercooled turbo diesel,2.5" exhaust, 32" maxxis at's. Now for sale. PM for details
Navie oiler
Unread post by Navie oiler » August 7th, 2010, 5:45 pm
has anyone got an Isuzu 4X4 with 6 speed auto?
chewy52
Re: dmax engine same as colorado?
Unread post by chewy52 » January 14th, 2014, 8:57 am
Mine is a 5 speed with lockup converter , so is it a ten speed ? !! I spend most of the time in sequential shift mode. if it wasn't for the traction ctrl i would be buying rear tires already , great grunt. Holden quote 2.8 Lt. displacement for the Colorado and the D max 3 Lt.
Unread post by mydmax » January 14th, 2014, 3:41 pm
chewy52
You probably will find it may only lock up the converter in the top two ratios. The lock up doesn't make it any more gears though and it will still be 5.
neilw59
Unread post by neilw59 » September 23rd, 2014, 8:40 pm
The July 2012 model onwards i.e. after they divorced were different engines, same chasis and some panels but outside of that different assembly lines etc. The DMax runs the Mitsui 3 L turbo diesel, the colorado runs the fiat 2.8 L turbo diesel.
Return to “General Isuzu”
