Engine Mounts - replacement
The new ute
pedropajero96
Unread post by pedropajero96 » June 6th, 2017, 10:13 am
Both my engine mount rubbers are split (and probably have been for some time)
Does anyone know the best way to replace them without having to dismantle too much
2011 Single Cab Chassis
ARB Bull Bar, Avenger Winch, XRay HIDs,265/70/16 Cooper AT3s,ARB OME HD springs/shockies all round with nominal 2" lift,LR fuel tank, additional 80lt tank under tray,Max Trax,GME UHF Radio,Mobile Booster ariel,GPS and Laptop runni
hoyks
Re: Engine Mounts - replacement
Unread post by hoyks » June 6th, 2017, 5:55 pm
I haven't done it on a D-max, but have on a Nissan:
Loosen off the bolts.
I got a hydraulic jack and sat it on a brick.
Stuck a block of wood under the sump and jacked the motor up so it leant to one side enough to get the old mount out and the new one in.
Repeat for the other side.
Once its all sitting where it should, only then tighten up the bolts.
It was the easiest way I could come up with, all I had to remove was the sump guard.
Return to “DMax”
