2009 DMAX - Anyone got the ECU pin configuration?
The new ute
roadster1986
Unread post by roadster1986 » August 6th, 2013, 11:10 pm
hi im after the ECU pin configuration on an 09 model dmax with cruise control. if anyone could take a picture of the ecu plugs showing the wire colours and position or have a diagram of the pin layout. that would be a great help. it would have to be with the same specs as my dmax i guess too. ive tried getting a diagram off isuzu of my transtron ecu but im not having any luck.
09 dmax crew cab
4x4
manual
transtron ecu
If anyone could help me in anyway that would be great. thanks
Matt RA7 Rodeo
Re: 2009 DMAX - Anyone got the ECU pin configuration?
Unread post by Matt RA7 Rodeo » August 16th, 2013, 8:28 am
Hi Roadster
Hopefully this is what you are looking for.
You can buy a workshop manual, on cd, off of ebay for about $10
roadster1986
Unread post by roadster1986 » August 16th, 2013, 6:06 pm
Its actually the wrong one I'm looking for. the 09 dmax has a different ECU to the colorado. Your pictures are for the colorado and earlier holden/isuzu. I have that workshop manual too. It doesnt give me the correct diagrams and there are no dmax manuals available. thanks for trying though.
roadster1986
Unread post by roadster1986 » October 3rd, 2014, 9:46 pm
Just a quick follow up. I have installed the holden rodeo/colorado cruise control kit into my 2009 dmax. I bought the kit from Holden and installed all the switches myself. Then took it to north east isuzu(adelaide) and had them enable the cruise in the ecu. Also had to change the connectors to the dmax ecu type plug.
The411
Unread post by The411 » January 2nd, 2018, 8:32 pm
do you have a diagram of the pins that you had to change?
roadster1986
Unread post by roadster1986 » February 2nd, 2019, 11:51 am
Sorry if i remember correctly i left the wires out of the ecu plug and the technician installed them when he updated the computer. The actual pins had to be changed to match the isuzu style plug, but i think i brought them online and he just crimped them on.
Return to “DMax”
