Got (or want) bigger tyres? Come in here!
The new ute
fisherman322
Re: Got (or want) bigger tyres? Come in here!
Unread post by fisherman322 » June 15th, 2015, 5:39 pm
Has anyone used Hub Centric Rings with steel wheels, CSA also can not guarantee against vibration :crazy:
Jeff
Unread post by mydmax » June 15th, 2015, 7:13 pm
Hub centric rings,( if not affecting rim centre face seating) would be better than non at all. The rings would transfer any radial forces which otherwise would be totally taken by the wheel studs.
Many trucks with a gap around the hub step would not be operating in the best situation.
ango
Re: Show us your dmax
Unread post by ango » June 25th, 2015, 5:15 am
Guys I need some advise/conclusion before ordering.
Does tyres 265//70/R16 or 265/75/R16 fit the new Dmax without 2" lift ??? (AT or MT)
Or is 245 the max. !! :crazy:
fisherman322
Unread post by fisherman322 » June 25th, 2015, 11:44 am
Are you going to use the same rims [ same offset] don`t own a later model but I think you would most likely be OK with the 265/70/16 ones, I would have my doubts about the 265/75/16 without a lift, I personally also think 265/75/16 are too big for this ute, but others will say different.
Jeff
rebo
Unread post by rebo » June 25th, 2015, 5:55 pm
I’ve got 265/75R16 tyres on 16x8 rims with no rubbing at all with +30 offset and no lift yet :)
ango
Unread post by ango » June 27th, 2015, 6:21 am
@rebo. do you have pictures of your Dmax with the wheels & tyres. ;)
rebo
Unread post by rebo » June 27th, 2015, 7:41 am
Hi Ango - the pictures aren’t the best, just off my phone but you get the idea that they fit okay.
2Dm4x
Unread post by 2Dm4x » July 10th, 2015, 1:15 pm
Hi Guys,
So I'm currently running the 17x7 Mu-x rims with the stock 255/65 r17 bridgestone HT's. Looking at filling out the wheel arches now that I have just got a lift. Just curious, on the stock rims what is the largest size I can go without cause problems with it exceeding the rims size limit?
2Dm4x
Unread post by 2Dm4x » July 13th, 2015, 11:25 am
"TG065
Hi Mate,
Are you in QLD? While legally you can go 50mm lift and 50mm increase in tyres are you aware that you can only legally lift your vehicle 75mm (lift & increase in tire size)?
With a 2in lift and the increase in tyre diameter your now at 78.3mm.
Anything over 75mm in QLD requires inspection by TMR.
Might want to look into that...
ango
Unread post by ango » July 15th, 2015, 6:51 am
WarnerDMAX
Hi Mate, could you provide a little more information/pic about the Fuel rims, model, or offset? Does it push the tyres/wheels right out to the guards?
cwcarter
Unread post by cwcarter » July 31st, 2015, 10:52 pm
Upgraded to 265/75-16
Matt28493
Unread post by Matt28493 » September 16th, 2015, 11:20 pm
Hi all,
I have a 2009 dmax.
I fitted 33"BF Mud terrains to mine. Needed to wind it up 2"s and trim the back side of the front arches slightly. Works beautifully on and off road. With standard and low tyre pressures. There's not much point applying a body lift as you can save some cash by just doing some trimming. They catch a small bit on the kick out of the chassis inside the wheel arch but we are talking about a few mm.
tjmark
Unread post by tjmark » September 18th, 2015, 6:23 am
Hi Matt, any chance of getting some pics or info up of how you trimmed your front guards? I'm running 285's and need to cut them back due to rubbing aswell.
Cheers. Mark
cliff0
Unread post by cliff0 » November 14th, 2015, 12:16 pm
"ango
i just bought some bridgestone a/t 265/65/17 and no scrubbing and vey happy with the tyres
fras
Unread post by fras » November 20th, 2015, 9:40 pm
Hey guys looking to buy a Dmax sometime soon, coming from a Ranger...
I'm hoping I can swap my Ranger wheels over -
They're 270/65R17 with 17x8 +35 rims... will these fit without a lift? Are they legal?
I also have a set of 265/65R17 tyres I could throw on the same rims, would they be any better?
Thanks so much!
Camping. Fishing. 4WD. '99 Hilux 5L with CT20 turbo Ute (sold). '88 Landcruiser Diesel Ute. '07 CRF250R. '82 XL185 (200cc)
CT20 Turbo on 3L/5L Hilux
Return to “DMax”
