Got (or want) bigger tyres? Come in here!
The new ute
Kellys_
Re: Got (or want) bigger tyres? Come in here!
Unread post by Kellys_ » February 23rd, 2015, 6:22 pm
are 31x10.50r15 legal for insurance purposes (NSW) on a rodeo ra 2007 (isuzu d-max 2009-2011)??
stock size is 245/70r16
WarnerDMAX
Unread post by WarnerDMAX » March 12th, 2015, 4:55 pm
Just got a new set of 17" wheels with 265/70/17 muddys... Car is not lifted and stil has the factory bumper. It does scrub but only on full lock and onky just on the plastic inner guard. A little bit of cutting will fix this aswell as having a bullbar would fix the problem too.... Would post pics but have no idea how.
cwcarter
Unread post by cwcarter » March 12th, 2015, 6:13 pm
I ended up going with 265/65/17 BFs. Should of went for the 70 profile....next time.
WarnerDMAX
Unread post by WarnerDMAX » March 12th, 2015, 10:24 pm
new wheels
LST Newie
Unread post by LST Newie » April 3rd, 2015, 7:37 pm
Warner, from what I can see they look good. Can you take a better pic so we can see them or tell us what they are so we can look them up or give us a link
Lord_Muck
Unread post by Lord_Muck » April 7th, 2015, 3:24 pm
Looks good WarnerDmax, what width are the rims and what are the offsets, cheers
WarnerDMAX
Unread post by WarnerDMAX » April 22nd, 2015, 9:10 pm
Hey guys, sorry haven't been on here in awhile! Thanks for your comments I'll take some more pics and put them up. I'm not sure of the rim width or offset is off the top of my head but I'm running 265/70/17 tyres and they look pretty good they are fuel rims I got them from a place in Sydney. Sorry guys for the lack of information haha
TG065
Unread post by TG065 » May 17th, 2015, 7:49 am
Hi Guys,
Thanks to all who previously posted info about their new tyre sizes.......it helped greatly with deciding which way to go.
Attached are photos of the original 255/65/r17 tyres
New tyres that are slightly bigger 265/70/r17 tyres. They are a "Summit Mudhog". Road noise is surprisingly low, about the same road noise as BF Goodrich A/T's I have had on previous cars.
I have a 2 inch lift and no rubbing or scraping of tyres
Thanks again to those who posted previously
fisherman322
Unread post by fisherman322 » June 10th, 2015, 8:12 am
Looking up the Isuzu site [what is my rim offset], they are saying a 2011 d-max has a off set of +38, later model use +33 . so I guess this is correct? http://www.isuzuute.com.au/owners/faq.aspx
Jeff
nosecohn
Unread post by nosecohn » June 12th, 2015, 2:09 am
Hi All. I'm new here and would appreciate some advice.
I have a 2014 D-MAX LS with the factory 245/70R16 tyres. I'm intending to change them out for something that's more all-terrain capable, but I'd prefer not to get new rims or lift the car. What's the biggest size I can put on without worrying about clearance issues, or should I just buy the same size to avoid any worries?
Thanks in advance.
fisherman322
Unread post by fisherman322 » June 12th, 2015, 7:24 pm
I`ve been looking at buying a set of after market steel rims, but I have found all makers I`ve contacted use the Hilux centre bore size of 106.1mm not the D-max C/B size of 100.1 .Speedy wheels said I may not get any vibration issue`s but they can not guarantee it, and of cause it can not be balanced out, Speedy said they use spacers in alloy wheels but the metal is too thin in the centre of steel rims. They explained the cost of tooling is high so most makers [ can not find any who don`t] use the most popular size`s eg Hilux. looking like I will be sticking to the original rims
Jeff
Kellys_
Unread post by Kellys_ » June 12th, 2015, 7:58 pm
fisherman322
I've had no problems with king wheels terra black steel wheel 16x8 +20 offset 139.7 PCD
Kellys_
Unread post by Kellys_ » June 12th, 2015, 8:00 pm
nosecohn
your best bet is probably 245/75/16 I'm not 100% but i think they will be fine, i run 265/75/16 which are a bit bigger on a 2 inch lift
nosecohn
Unread post by nosecohn » June 13th, 2015, 5:43 am
Thanks Kellys_
So, definitely don't go wider, huh? I was thinking about 265/70R16, but I definitely don't want to modify anything. Is anyone running that size on a stock D-Max with stock rims?
fisherman322
Unread post by fisherman322 » June 13th, 2015, 2:17 pm
Kellys_
Thanks mate but!
I did not want to go to +20 , only as far as +25 at most { to keep it near legal }, but king wheels only make the +20 in 16x8s, Speedy and CSA make +25 and Speedy will not guarantee against vibration, anyone run the CSA steel wheels, I will give them a ring next week to see what they say? the rims on my 2011 D-max are +38
Jeff
Return to “DMax”
