show us your scats
Waitesy
Re: show us your scats
Unread post by Waitesy » January 6th, 2012, 5:51 pm
man that is a shame it doesn't take alot to break them unfortunalty what gonna happen to it now?
My Rigs:
1982 HJ47 troopy cut down, lifted and locked.
1988 HJ75 ute slowly getting rebuild.
1985 HJ60 coiled comp truck.
as we grow older, we don't grow up our toys just get bigger and more expensive.
Ammann
Unread post by Ammann » January 6th, 2012, 6:13 pm
Yeah I am gutted. I'll try and find another body, but they are pretty rare. This one was almost perfectly straight too. Two centimetres to the left and I wouldve missed it. I am amazed at the damage.
Driving for 11 years and its the first time I've ever hit anything.
vaggelis
Unread post by vaggelis » January 29th, 2012, 6:40 am
Here is my beauty! Its an f10l with a toyota 4k engine.. Firstly i want to do a disc conversion with an f70 axle. Then i want to run an other more powerful engine.. Any ideas?
edz
Unread post by edz » January 29th, 2012, 9:30 am
Upgrade the front axle to a 1980's disc type from an F-20 with booster, you already would have an alloy adapter between the bellhousing to gearbox to fit the toyota motor up ..You could probably redrill that to suit an escort / cortina bellhousing and throw out bearing carrier.
I had to make that part when I converted a 2.0 ltr ford escort motor into mine, engine mount blocks were made up out of 100mm x 50mm duragal box welded to the chassis .. to take the standard escort rubber mounts..F-20 radiator with top hose moved to the opposite side was spaced back from the front support aprox 75mm and a standard escort fan and shroud was fitted and used .. had twin thermo fans on at first but it kept over heating..
TE cortina accelerator cable( same as escort but longer ) fitted to a modified accelerator pedal top ( just welded on an escort one ) ..
Escort clutch throw out leaver at the bell housing was converted to a hook to take the standard diahatsu clutch cable,a toyota clutch plate is used with the escort clutch preasure plate and a bronze spigot bush is made to suit the diahatsu gearbox imput shaft end / escort crank, a set of escort extractors was shortened in the down tubes to suit and fitted to a 2.5 "free flow exhaust.. very good power to be had with these free reving engine's with the low gearing of the diahatsu's . only drawback was it realy needed a 5 speed gearbox from an F-50 diesel as it pulled aprox 4000 + rpm at a 100 klmh on the highway..
" WE GO WITH WHAT WE'VE GOT "
vaggelis
Unread post by vaggelis » January 30th, 2012, 6:48 am
i m thinkin to put the toyota 3Y engine with rocky's gearbox. Well, i have a broken cv joint and must fix it. Do you know if rocky's cv joint is the same?
edz
Unread post by edz » February 2nd, 2012, 4:12 pm
Hey Vagg.
Think you'd have dramas with a rocky shaft as they are aprox 150mm longer overall side to side in the diffs.. As for the 3Y they are gutless and heavy on fuel, Well my 3Y powered Rocky is , even after it was rebuilt and with extractors and a towing cam added ... It wouldnt pull a sailor of my sister .Also the Rocky gearbox and transfer I think may give you trouble with clearances ( think the rocky is longer ) also the rocky box is weaker than the scat and a lot higher geared , also Rocky's have their handbrake set up in the rear brake drums and Scats are on the transfer case rear out put shaft ..
The 3Y Rocky realy does struggle on hills and when loaded with a light weight camper trailer in the sand tracks going to Double Island Point and the barges to Fraser Island ..
vaggelis
Unread post by vaggelis » February 2nd, 2012, 7:59 pm
well edz have a look at this http://seekpart24.com/jakoparts/joint-k ... t-j2826007. The dimensions are exactly the same so i believe that 'll fit. I also read this http://daihatsu4x4.eu/viewtopic.php?t=894 so i think tha everything will be fine! THank you for your interest! Keep in touch
Dovewood
Unread post by Dovewood » April 27th, 2012, 2:32 pm
I have a 1975 F10L that I am trying to fix up but I need a wiring diagram. Does anyone know where I can source that from?
DAT MAN
Unread post by DAT MAN » May 31st, 2012, 12:43 pm
You might find a service manual on ebay it is comprised of 2 books one for the driveline and the other for the bodie if you have on luck P.M. me as i have both and can Email a scan of it to you, What seems to be the problem any way?
Sparkys
Unread post by Sparkys » May 31st, 2012, 1:13 pm
There are many different Scat series, the pic below shows a lot of them.
scats96
Unread post by scats96 » June 1st, 2012, 8:24 pm
hey dat man if possible could i please get a copy of the service manual i tried to pm you but it didnt work
Cheers Bailey
DAIHATSU SCAT F50 IN PROGRESS
Elblado
Unread post by Elblado » June 10th, 2012, 8:35 pm
Heres my 1981 F50. 2.5 Diesel and all orginal. Was a farm workhorse but just spent a few grand on it bringing it back to life. New 2pac paint job, suspension, brakes, wheel bearings, seat belts and other general maintenance that hadn't been done for years. Improved the gearing slightly by fitting 31x10.5 tyres (not in photo) sits comfortably on about 90kms/hr which is enough to get me out to the dirt or the beach. Built a shelf in the back and can remove the front passenger seat and extend to allow me to sleep in it overnight and Im 5ft 10in!! there is nothing these little beauties can't do. Its starts first go, idles like an old cat and has all the complexity of a lawn mover. 2 hoses and a belt thats all I've got to worry about.
1992 Rodeo DLX- The Wheelbarrow
2014 Toyota Prado
scats96
Unread post by scats96 » June 12th, 2012, 6:24 pm
hey everyone does anybody no what starter motor will fit the 2.5 DG engine or part number i bought one but it was the wrong one
cheers Bailey
DAT MAN
Unread post by DAT MAN » June 14th, 2012, 9:21 pm
"scats96
Hay dude I dont have a diesel manual I don't think I'll have to look though my collection though and see if I do, I'm always buying daihatsu stuff sort of hard to keep track of sometimes haha :D
Elblado
Unread post by Elblado » June 18th, 2012, 7:32 pm
Ive got the DG engine manual, workshop manual and owners manual on PDF. What exactly are you after?
2014 Toyota Prado
Return to “Scat”
