show us your scats
edz
Unread post by edz » February 25th, 2010, 1:27 pm
Hah... That looks almost exactly like a photo of my F20 scat on a trip to Landcruiser mtn park.. These little trucks sure did like to lift a wheel, Had mine that far over once, the roof mounted UHF mike, fell out the passenger window, No the truck didnt roll. But by christ it was a very close thing... I put a worked 2 ltr Escort motor into mine, worked real well with the low gearing the truck had ... "Sounded like a rally car at full noise " most of the time sure turned some heads.. But the rust got to much and she went to the scrappers..
" WE GO WITH WHAT WE'VE GOT "
Tropical Low
Unread post by Tropical Low » February 25th, 2010, 4:13 pm
Good stuff mate! it's a shame the rust got her in the end but at lest you had a lot of good times in her:waycool:
edz
Show us your Scats
Unread post by edz » February 25th, 2010, 11:46 pm
Hey tropical, Just a couple of pic's of the O'l Scat at Landcruiser Mountain Park..2 liter ford powered,Ported Hi compresion head hot street cam,4 speed box.. 2.5" inch exhaust free flow muffler , The adaptor I made to link the ford bell housing / clutch etc etc to the diahatsu box.. :D
Tropical Low
Unread post by Tropical Low » February 26th, 2010, 11:45 am
Good work mate that thing would of gone like a demon:truck:
edz
Scat
Unread post by edz » February 26th, 2010, 1:37 pm
Took it to Operation Drag a few times ( A Drag race event run by the local coppers, to get along with local car enthusiests / race on a strip instead of the street & also to race the coppers ) The O'l girl ran a PB of 18.8 for the 1/4 mile.. Flogged a turbo six cruiser that ran a flat 26 for the 1/4 ( think I kinder had the weight advantage on him..He was all mouth up untill the end of the runs )..realy was an absolute Fun machine to drive, Good usable power in a nippy / tuff package.....:thumb::D Ever thought a bout repowering the Zook...??? Wouldnt be that hard to give one of them a decent heart, We had a soft top Zook down here a few years back,That had a 13b Rotory - 5 sp in it.. not sure if was legal ( Probably not ) By Jeez it went ...He was one very game bloke .. No roll cage...
Tropical Low
Unread post by Tropical Low » February 27th, 2010, 12:02 am
Nar edz mate still gona stick with the big block 1.3:D some people put the 1.6 Vitara motors in the Sierra give em bit more stick ezy fairly cheap conversion. The rotory mite be a bit hard to keep it on it's wheels:crazy:
Waitesy
Unread post by Waitesy » March 11th, 2010, 7:49 pm
was my Daihatsu Scat (f20 with 2ltr petrol engine) (yellow) till i sold it to a mate:cry: should have kept it, brought another 4x4, sold it cause i wanted another scat so im going to pick 1 up on saturday a f50 (the blue 1) can't wait:waycool:
edz
Unread post by edz » March 11th, 2010, 11:31 pm
Looks like she's a nice clean unit there WAITESY,Got much planned for it ???, F50 you say, they were a 2.2 deisel with five speed box wernt they ???? A bloke some years back fitted a 253 Holden V8 into one of these. ( A range rover 3.5 would have been better, only for the weight factor ) . Yep a tight fit but had plenty of poke.... Had a two liter escort motor in mine but only had the four speed box.. They sure are tuff little trucks, Wish I still had mine... :waycool::D
Waitesy
Unread post by Waitesy » March 12th, 2010, 6:49 am
edz wrote:Looks like she's a nice clean unit there WAITESY,Got much planned for it ???, F50 you say, they were a 2.2 deisel with five speed box wernt they ???? A bloke some years back fitted a 253 Holden V8 into one of these. ( A range rover 3.5 would have been better, only for the weight factor ) . Yep a tight fit but had plenty of poke.... Had a two liter escort motor in mine but only had the four speed box.. They sure are tuff little trucks, Wish I still had mine... :waycool::D
yeah edz its fairly clean (had been sitting in a shed for 7 year then this guy brought it for his daughter but she didn't want it because it was too old) so i brought it off him for $1000. plans for a start are fix a little rust get it regoed then later on i want to put a holden v6 and wider diffs. its a 2.2 4spd.
Waitesy
edz
Unread post by edz » March 12th, 2010, 12:06 pm
AAHHH ! Wider diffs, Yep that is one thing these little trucks do need.. V6 power would be real nice too, Need to fit a second fuel tank though, found the range of mine was a bit short..You thinking Rocky diffs or hilux ?? with coils on the front... The only reason I say coils is they would fit out board of the chassis rails ( they are a bit skinny on width ), From memory the original leaf spring position on the front end and the diff centre of the wider diffs foul on the drivers side.. I did look into fitting rocky diffs and I'm sure that was the only drama other than flared guards, brake lines ,steering.. Should be a real nice truck....
Waitesy
Unread post by Waitesy » March 12th, 2010, 3:52 pm
edz wrote:AAHHH ! Wider diffs, Yep that is one thing these little trucks do need.. V6 power would be real nice too, Need to fit a second fuel tank though, found the range of mine was a bit short..You thinking Rocky diffs or hilux ?? with coils on the front... The only reason I say coils is they would fit out board of the chassis rails ( they are a bit skinny on width ), From memory the original leaf spring position on the front end and the diff centre of the wider diffs foul on the drivers side.. I did look into fitting rocky diffs and I'm sure that was the only drama other than flared guards, brake lines ,steering.. Should be a real nice truck....
yep there sure arn't wide, i had a v6 in my last car was always racing my neighbour down the paddock was fun, plenty of power but wanted somthing a little less rusty so i brought the scat, i was thinking 1 day when i save some money buy a gq chassis and and put the diffs and coils etc under the scat but there just dreams at the moment.:thumb:
Wellsie
Unread post by Wellsie » July 2nd, 2010, 4:01 pm
2 mates and myself have just been given a scat, not sure what model it is. It seems to be a little different to the ones pictured - it's kind of like a style side ute. Mybe just looking at it wrong. It's a petrol of some description.
It's rusty as, so it will only ever be a off road toy.
We are planning on doing a spring over convo on it, What shocks should we get, We're hoping to just use parts from wrecker - we all already have other 4bies to blow our money on.
Any other hints or tips would be greatly appreciated.
Picks to come.
bruggz351
Unread post by bruggz351 » July 2nd, 2010, 4:55 pm
:D:DI like scat of a different kind:D:D
YouTube - Scatman John - Scatman (Ski-Ba-Bop-Ba-Dop-Bop)
enjoy:thumb:
I know i'm in my own world;It's ok, they know me here.:)
I set my standards high.Actualy, i do a lot of things high.
If everything is comming your way,you're in the wrong lane.
I recently took up meditation. Sure beats sitting around.
shambles
Unread post by shambles » July 2nd, 2010, 8:23 pm
great clip, tnx dude
crazyfreak4321
Unread post by crazyfreak4321 » July 7th, 2010, 1:57 pm
what the hell is a scat?
Return to “Scat”
