Will a Rocky cv joint fit my f10 Scat?
vaggelis
Unread post by vaggelis » January 27th, 2012, 6:48 pm
Hello everyone! I m an f10 owner and i writing from Greece.
Well, i a have o broken cv joint and i cant find anything in here for my daihatsu, so i am wondering if rocky's cv joint is the same...
thank's a lot!
Mr Scat
Re: Will a Rocky cv joint fit my f10 Scat?
Unread post by Mr Scat » February 10th, 2012, 8:25 pm
I know the later scat's were the same as the early rocky's but not sure about earlier models. I only found that out for sure by removing mine and measuring it and counting the splines then emailing a supplier. Luckily I found someone willing to open a box and do the measurements (most would have just said they had no listing). Try some UK sites, they were sold as a Daihatsu Taft there. I've got a few bits imported from UK as I couldn't find them in Australia.
F-65 DL-T 5sp 2" lift
scats96
Unread post by scats96 » June 13th, 2012, 12:48 pm
whats the site you went on from the uk.
DAIHATSU SCAT F50 IN PROGRESS
vaggelis
Unread post by vaggelis » June 13th, 2012, 5:46 pm
actually it's the same.. i ve done the conversion
Mr Scat
Unread post by Mr Scat » June 16th, 2012, 1:31 pm
scats96 wrote:whats the site you went on from the uk.
http://www.milneroffroad.com/
Mine is the last model of the Scat's (F-60/65) so quite a few Rocky bits fit. I bought new tie rod ends, a couple of gaskets and gearbox/transfer case mounts from there. Was a lot cheaper than what I could find here even with freight. For example the left side tie rod end was about $85 here and from the UK was about $15. That saving alone paid for the freight.
There is also http://www.warfs.org/ Not an online store but a lot of information. Again, handy for me because of the correlation between the late Scat's and early Rocky's. Not sure how much help it will be with your model.
Return to “Scat”
