Replacement Gearbox/Transfer
DiGiT
Unread post by DiGiT » October 8th, 2015, 10:03 pm
Hey All,
So, it looks like I could have blown up the gearbox or transfer case, and to get them reco'd would be pretty major money, money I don't really have. Seeing how rare Rocky's are, and how slim my chances are of finding an F78 being wrecked with a good 'box and 'case, I'm wondering whether anyone has used the gearbox or transfer from another car like a Hilux or something?
Hope you guys can help me out!
Marty
Daihatsu Rocky 2.8L Diesel Intercooled Turbo
www.turnedon.com.au
Rogers Cruiser
Re: Replacement Gearbox/Transfer
Unread post by Rogers Cruiser » October 8th, 2015, 10:47 pm
Are the rockys seperate cases (driveshaft on bothsides) like some suzukis or are does the transfer attached to the back end of the gearbox?
DiGiT
Unread post by DiGiT » October 9th, 2015, 9:46 am
Hey Mate, looks like it's mated directly onto the gearbox, from the transfer the driveshaft and tailshaft go to the diffs, but no shaft (that i can see) linking gearbox and transfer.
www.turnedon.com.au
Rogers Cruiser
Unread post by Rogers Cruiser » October 9th, 2015, 10:42 am
Yeah then you will need a rocky one, the chance that something else will make up is tiny.
Unread post by Peter Aawen » October 9th, 2015, 12:59 pm
You could check out the same or earlier vintage vehicles from Toyota, lots of the mechanicals on the Rocky/Feroza's were cloned from things like Hilux's, Hiace's, & Dyna's - but little was a direct swap, even if the internals were identical!! For example, I fitted some of the gears/shafts outta a Hilux into a Feroza trans case to get a lower Lo ratio; & bolted the guts of a Dyna diff into a Feroza housing, straight bolt in, but none of the housings or gears & shafts would swap directly & I still hadta source & fit shortened Hilux (or Hiace's?!) axles to get the drive to the wheels..... :(
I think you might hafta keep looking for the boxes from a Rocky, sorry.
DiGiT
Unread post by DiGiT » October 9th, 2015, 1:07 pm
Yep it's looking that way. Pity, was hoping it'd be a great chance to throw in a hilux transfer and put in reduction gears.
Interesting options, thanks Peter. I'll see if I can find anyone who's done something similar for a Rocky.
www.turnedon.com.au
NZRocky
Unread post by NZRocky » March 8th, 2016, 10:11 am
Have you had any luck mate? Got a few rocky bits over here in NZ but getting them to you could be a challenge.
DiGiT
Unread post by DiGiT » April 19th, 2016, 11:57 am
Hey NZRocky,
Got an older floor shifter from a wrecker over here and it's a bolt on fit. The ratios are out a fair bit though, eg, if the speedo reads 50, i'm doing 60.
www.turnedon.com.au
Return to “Rocky”
