Ordered front & back Protrack Airlockers from Greece.
storky
Unread post by storky » September 1st, 2012, 3:09 pm
Bit the bullet this week and ordered front and back air lockers from Protrack in Greece. Should be here in about 4 weeks.
Be interesting to see how much mucking around there will be.
Stay tuned...
shambles
Re: Ordered front & back Protrack Airlockers from Greece.
Unread post by shambles » September 3rd, 2012, 8:03 pm
Holy crap $$$$$$$$$$$, can't wait for the fitment and road report.
storky
Unread post by storky » September 4th, 2012, 1:37 pm
Price doesn't seem to be that bad, 2 x lockers and compressor 1200 euro ( less than $1500) and 120 to150 euro for freight.
Only trouble at the moment is I have to pull my diffs apart to get some measurements for them so when I get them, they drop straight in without mucking around with reshiming them again. And when they get here I have put the gears from my diffs into them, the back diff as 6 x gears in it and the front only 4.I do have a spare rear diff so I'll be taking the 6 x gears from it and fitting them to my front diff just to make it stonger.
Fun and games!!!
shambles
Unread post by shambles » September 5th, 2012, 5:11 pm
That's a cracking price for front and rear lockers.
storky
Unread post by storky » September 28th, 2012, 1:59 pm
Lockers have finally landed in Australia, Now just waiting for Australia Post to Deliver them to me in Airlie beach.
Hopefully by the end of next week.
storky
Unread post by storky » October 5th, 2012, 6:45 am
They have arrived! This is what you get. Two lockers (no internal gears, use one's out of Rockys diffs.) Wiring harness ready to go. compressor and hose.
Got my weekend sorted.
DiGiT
Unread post by DiGiT » October 5th, 2012, 1:36 pm
What model Rocky are you putting these in? And what about cabin switches or how do you activate them?
Daihatsu Rocky 2.8L Diesel Intercooled Turbo
www.turnedon.com.au
storky
Unread post by storky » October 5th, 2012, 3:00 pm
My Rocky is a F75 10/92 model, live axles. They sent over rocker switches, 1 each for each locker and 1 for the compressor.
But I bought 3 x AOB rocker switches of EBAY. (ARB look a likes). I'll put some more photo's up when I finish fitting them.
They work similar to ARB air lockers.
storky
Unread post by storky » October 6th, 2012, 8:22 pm
Front locker all done!! A couple of little hiccups but sorted them out with a die grinder, start on the rear on hopefully tomorrow.
[attachment=0]photo5 (768x1024).jpg[/attachment
storky
Unread post by storky » October 7th, 2012, 7:03 pm
Got the rocker switches and compressor fitted today, the switches I used I got of Ebay.
Fitted switches where a useless coin holder was, cut it out and it made a perfect holder for 3 x switches.
The compressor fitted just behind the battery, made a small bracket for it to bolt to.
And a photo to show what had to ground in the diff housing, it so you can fit the air pistons in properly.
Need another spacer for back diff before it goes in, hopefully in the next few days.
storky
Unread post by storky » October 11th, 2012, 8:22 pm
Rear locker all done. Little bit of trouble as I had to get the side gear lathed so I could fit the thrust washer properly.
Rocky is all back together now, been for a hi way test drive, all good.
I did replace all bearings and seals in diffs, wheel bearings and swivel hubs as I went along as well.
Have to wait for a week or so till can really test them. (other commitments)
And if everything goes good I'll be putting some footage on utube.
Let you know when I do.
shambles
Unread post by shambles » October 26th, 2012, 1:26 pm
How did it go. awesome I guess :lol:
storky
Unread post by storky » October 29th, 2012, 12:56 pm
Hi shambles, at the moment all good, haven' t given them a real torture test yet but what I have done they worked great. I'm hoping to give them a work out this weekend.
storky
Unread post by storky » October 31st, 2012, 6:41 pm
Here is my first attempt videoing and editing, it's only the first test run and not to challenging.
The hill climb before I get to the camera is a lot steeper than it looks. Hopefully better footage next time.
http://youtu.be/3IlOUEF15lA
jakob
Unread post by jakob » November 4th, 2012, 1:41 am
Just saw the thread, the vid looks great, the rock makes it up there hell easy.. Im thinking i'll have to get a set for my f77.. How much did both lockers cost landed (including import duties)??
Return to “Rocky”
